How to position code via SEGMENTS directive
I am using Keil C51 toolset with C51 COMPILER V9.53.0.0 and LX51 LINKER/LOCATER V4.66.30.0
and a device with a 64K code space.
I am using the SEGMENTS directive
SEGMENTS (?PR?*?btldr( C:0xE000 ))
To position all of the code in the "btldr.c" module in a segment starting at 0xE000. I can
get that working, and see in the .COD file that it is indeed there.
I then add a single function to btldr.c
void test( void )
{ val++
and recompile. It is no longer positioned at 0xE000. It is NOT an issue that there is
not enough room in the segment. I can change it to 0xD000 and it still is not positioned
there.
Can someone explain why this might be happening ?
Thank you
  • I believe I may have accomplished my goal. I used the Userclass directive at the
    top of btldr.c,
    #pragma userclass (code = IAP)
    And then the CLASSES directive in invoking the LX51 linker
    CLASSES( CODE_IAP (C:0xE000 - C:0xFF00 ))
    In looking at the listing output it appears this is what I wanted.
    I am still curious as to why my initial attempt failed the way it did.
    Thank you.
