Timing of data on serial ports
Call me crazy if you like but I decided to make myself a dual serial port system for the 8051 (AT89S52) via hardware multiplexing (4052 IC) in which the uart selection is controlled by a GPIO pin. The crystal attached is 22.1184Mhz. I did it because I have a radio module (model: HM-TRP) that has a uart and I'm also connecting it to the PC as well. Ideally, I want to use the 8051 to allow the PC through a friendly terminal interface to program the radio module.
The issue I'm having which isn't really documented is the timing of serial operations.
I'm looking at a speed of 56Kbps. I set PCON.7 to 1 and I followed the baud rate chart and set my timer 1 reload value to FEh. This works nice for the only one hardware uart on the 8051.
My idea to streamline both serial ports is to enable one for a fixed window of time, then switch to the other one for a fixed window of time. The problem is I don't know how to calculate such window efficiently. If I make the time incorrect, then some bits will be cut-off (thereby producing a framing error).
Because I'm using the 8N1 format and 56k speed for serial data on all devices, I believe that the 8051 makes a scan after 10 incoming bits to see if the data is present or not. For this reason, I also included a decade counter on board (CD4017) that can go to 10 (or 9) and then trigger an interrupt to offload work from the processor. then I'm thinking implementing a serial function like this (assume a jump was executed from the vector address before the instructions below start):
serial_1_timer_interrupt:
  cpl TIMER ;set clock line on the 4017 in opposite state
reti
INT1_interrupt: ;triggered when Q5 on the 4017 goes low
  jbc SERIAL_RECEIVED,notbad
    cpl UARTLINE ;select uart line:  clear=1st uart, set=2nd uart
  notbad:
reti
serial_interrupt:
   jnb RI,notreceived
      setb SERIAL_RECEIVED ;set software flag if data received before time runs out
      mov @R0,SBUF
      inc R0
      clr TIMER ;set last so nothing bad happens if interrupt is triggered
   notreceived:
   clr RI
   clr TI
reti
But then again, I might have to step speed down to about 38.4K to prevent stalls in the timer interrupt.
I know i may need to put a bit more thought into the code, but is this the most practical way to do this? I mean I want to make things as multitasking as possible (example: send data from PC to micro while reading a byte from radio module)
  • You're crazy!
    In this day and age, why on earth would you faff about with this when chips with 2 (and more) UARTs are so readily available?!
    Even 8051-based chips!
    But, anyhow, the operation of the UART is clearly documented in the so-called "bible" for the 8051:
    80C51 Family/80C51 Family Architecture: ecee.colorado.edu/.../p8051arc.pdf
    80C51 Family/80C51 8-bit Microcontroller Family Data Sheet: ecee.colorado.edu/.../p8051ds.pdf
    80C51 Family/80C51 Family Hardware Description: ecee.colorado.edu/.../p8051hw.pdf
    80C51 Family/80C51 Family Programmer's Guide and Instruction Set: ecee.colorado.edu/.../p8051pg.pdf
    The UART operation is described in the Hardware Description document - see p 11.
    It tells you how the bits are sampled, and when the interrupt flags are set relative to the byte reception/transmission.
  • Call me crazy if you like
    I like, You're crazy!
    as Andy say above there are legio '51s with multiple Uarts e.g. each and every of the 100s of offerings from SiLabs.
    a 'switched UART' WILL lead to lost data, remember Murphy was an optimist
  • ...Lost data if I'm not careful. Since the radio module works only in half-duplex mode I can make the connection to the PC in half-duplex mode as well. Why not newer chips? Price is higher and considering each chip has a finite number of write cycles, I'd rather spend less per chip.
    I'm also not asking for ridiculous speed either. Just a method of doing this that can work with my microcontrollers because if I buy a specifically designed 2-uart one and they run out and mine decides to no longer work, then I'll eventually have to learn to program 2 uarts on one micro
    Just out of curiosity, is there any other 20-pin 8051 chip out there besides the AT89Cx051?
  • The HM-TRP uses an 8051 SiLabs based part, SiLabs also has a new radio EZR32 using a Cortex-Mx with more memory and easier development library.
    www.mouser.com/.../
    Most UART implementations over sample the input signal (by 8 or 16x) so they can align/center the bit timing of the input signal. Most cases the internal clocking and framing is not exposed. The UART accumulates bits after recognizing the START bit, it doesn't wait for 10 bits to make decisions.
    Perhaps you might want to review classic computer architecture designs and texts related to UART design/function.
    It's practically 2018, not sure I'd be wasting time on archaic 8-bit micros, almost entirely irrelevant in today's job market, and there are a wealth of old white guys who know there stuff backward and forward.
    Or 4000 series logic, some CPLD/FPGA skills would be more helpful, and some experience with logic design to a few thousand gates. Look at some VHDL or Verilog UART implementations.
  • Now you really are talking crazy!
    I just did a search at RS:
    The cheapest AT89S52 is £1.46
    uk.rs-online.com/.../
    A search of all microcontrollers with 2 or more UARTS has four pages of chips costing less than that!
  • The reason why I'm doing a 10 bit sample approach is because I'm creating a specialized wireless network with the radio modules and one device is connected both to the network and an old PC. So I need to establish a method in 8051 to detect when its time to move on to the next uart.
    I looked at the bibles one mentioned and it only tells me that a flag is set if the data is received and according to the phillips manual, I can see what the last bit received is in RB8.
  • Ok, just because of timings and because I calculated that I can't get better than 19kbps with my approach, Ill try a new chip. I'm looking at w77e58 but i'll look at others if they are DIP and cheaper too
    Now I gotta wait 30 days to continue *sic* due to non-local availability of parts
  • Well, crazy is as crazy does!
  • I guess they have to wait for the portal to open back to 1998 ?
  • I'll get you some. Just gotta ask Doc Brown for the keys to his DeLorean.
