hello
i am working on a project with stm32f205 and keil uvision5.
i am using the cmsis rtos.
when i plug the usb to my board the usb tasks are created quickly.
the problem is when i unplug the usb , for removing the usb task i use this functions : Usb_Status = USBD_Disconnect(0); Usb_Status = USBD_Uninitialize(0);
but it takes too much time to remove the usb tasks (about 6 to 8 seconds).
i have verified and it seems that the program is bloking in this part :
while ((OTG->GINTSTS & OTG_FS_GINTSTS_GONAKEFF) == 0U);
this code is part of the file : USBD_FS_STM32F2xx.c (static int32_t USBD_EndpointUnconfigure (uint8_t ep_addr)).
thanks.
Hi Zakaria,
could you contact support and provide an example code that issue can be duplicated?
Best regards, Milorad
