I installed the latest version of MDK --- uVision5.10 today, but i met an error within embedded assembler in my project
the source code is simple as below:
__asm void OS_TO_PRIVILEGE(void)
SVC
NOP
BX LR
ALIGN
But compiler always report error after building.
error: A1110E: Expected constant expression
I am sure it was correct in previous MDK version like v4.xx, But now it doesn't work....
Attached system info in PC
The instruction SVC requires a constant argument. This error was not trapped in V4.xx but is not correctly reported. Change the code to:
SVC 0
Thanks for help
Did you see who answered your question? Keil!! The man!
