I have a problem that involved "Mailbox overflow detected " in RTX.
I uses RTX and attempt to implement the Uart communication between Stm32f3 board A and B.
I describe the flow as the following:
[1]Board A send the command to board B, Then Board B periodically return data to broad A .The circle of term is sett to 0.15msec.
[2]Secondly, Board A send to Board B new command , Then Board B return ACK only once.
[Ploblem] When I executed only procedure [1] or only procedure [2], I don't encountered error. But I executed both procedure [1] and procedure [2] , Then I encountered "OS_ERROR_MBX_OVF".
In addition, If I set the mailbox in board B as the folloing:
osPoolDef(send_rs232c, 1, COMMSG_Typedef); osPoolId send_rs232c;
osMessageQDef(send_rs232c, 1, COMMSG_Typedef); osMessageQId send_rs232c;
I executed procedure [2] twice , Then "OS_ERROR_MBX_OVF" is occured. If I change the above value to 3, "OS_ERROR_MBX_OVF" is occured after I executed procedure [2] forth.
After I execute osMessageGet , I execute osPoolFree ,but I encountered the above issue.
Please let me know some advice for me .
