Want to declare an assembler function (to be called from standard C) for a Cortex-M3 (LPC1343) like this:
__asm uint32_t RevBytes (uint32_t data) { rev r0, r0 bx lr }
Using armcc.exe V5.06 update 5 one gets error message "error: expected '(' after 'asm'"
So it seems that keyword "__asm" is not known by Compiler.
What is the correct syntax to use?
Best regards Juergen
What does the compiler manual say?
