With most examples outside of the Keil examples there are pages of defines that set up the pins. Keil has this all built in to config sections. I have a usb example that requires me to use an external pull up. Though I have another example that configures the pin to pull up and I do not need this external pull up. So with the Keil USB example I want to do the same thing and pull up in code. Is there a section I can do this in? I though maybe the RTE does all the pin config but I see no option for pull up.
