I was hoping for some help and clarification to make an effective and useful scatter file.
my goal is to put all my bootloader files into region 0x0000 - 0x3FFF and then all of my application files in 0x4000 - 0x800000. I have my bootloader and a small demo of blinking an led as my application. I am having issues linking the application to the correct place. I have looked into alot of the ARM guides but still am having issues.
I am getting this error: .\Objects\shitty_scatterfile.sct(24): warning: L6329W: Pattern BlinkyDemo.o(RO) only matches removed unused sections.
here is my crappy scatter file
LR_IROM1 0x0000 0x3FFF ; bootloader objects go here { ER_IROM1 0x0000 0x3FFF; bootloader executable region { *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } RW_IRAM1 0x20000000 0x00010000 { ; RW data .ANY (+RW +ZI) ; store this data anywhere } } LR_IROM2 0x00004000 0x00080000 ; Application objects go here { ER_IROM2 0x00004000 0x80000 { ; load address = execution address BlinkyDemo.o (+RO) } }
the section: *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO)
is straight from the generated scatter file so if someone could also explain the *(InRoot$$Sections) to me that would be great. I think my issue is that I am linking "BlinkyDemo.o to both Rom1 and Rom2.
Thanks,
Eric Micallef
I'd recommend having the boot loader, and application as separate projects.
Hi Clive ya, after reading through some posts I see that everyone was doing seperate projects so I started doing that. in my startup assembly file I have the INCBIN
AREA AppDemo, CODE, READONLY, PREINIT_ARRAY INCBIN C:\SWARM BOOTLOADER\NRF52_BOOTLOAD_ADV-master\NRF52_BOOTLOAD_ADV-master\Objects\AppDemo.bin END <\pre> is there anyway I can specify in the scatterfile or in this INCBIN to start placing the binary file at 0x4000? I am referencing this post. http://www.keil.com/forum/18585/
Hi Clive, I got it!
thanks for the multiple project suggestion (:
