SystemCoreClockUpdate declared implicitly
I am trying to write some really basic code for the ADuCM3029 from ADI.
It all compiles OK, except for the error message:
aducm3029_test.c(90): warning: #223-D: function "SystemCoreClockUpdate" declared implicitly SystemCoreClockUpdate();
I have copied the system_ADuCM3029.c (that contains the SystemCoreClockUpdate function) file into my RTE folder
and the compiler has this folder in its include path, so I cannot see what the problem is.
For info, here is the applicable code:
 #include <stdint.h>         // needed for the int32_t definition
//#include <system_ADuCM3029.c> // needed for SystemCoreClockUpdate
#include "aducm3029_test.h"     /* stick all the header stuff in here */
#include <ADuCM302x.h>          /* stores register and bit names */
#include <ADuCM302x_device.h>          /* stores pointers to registers */
/* CLOCK FUNCTIONS                                                  */
void initialise(void)
    /* Enable internal HF oscillators */
    // disable key protection for clock oscillator
    pADI_CLKG0_OSC->KEY = 0xCB14u;
    /* Switch on the internal HF oscillator */
    pADI_CLKG0_OSC->CTL |= BITP_CLKG_OSC_CTL_HFOSCEN;
    /* wait for HF OSC to stabilize */
    while ((pADI_CLKG0_OSC->CTL & (1U << BITP_CLKG_OSC_CTL_HFOSCOK)) == 0u)
    /* Miscellaneous Clock Settings */
    /* Use internal HF oscillator for PCLK and HCLK */
    pADI_CLKG0_CLK->CTL0 &= BITP_CLKG_CLK_CTL0_CLKMUX;
    /* set CLK control Reg 0 later when you start using peripherals */
    /* leave Clock Control Regs 1 and 3 as default settings  */
    /* configure Clock Control Reg 5 (clock gating for peripherals) when needed. */
    /* meanwhile, keep with default values */
/* POWER MANAGEMENT FUNCTIONS                                       */
                pADI_PMG0->IEN = 0x0000;             // disable all interrupts
                pADI_PMG0->PWRMOD = 0x0000;  // keep in active mode
                pADI_PMG0->CTL1 = 0x0000;            // keep buck converter off for the moment
    /* enable LF crystal oscillator */
    pADI_CLKG0_OSC->CTL |= BITP_CLKG_OSC_CTL_LFXTALEN;
    /* wait for LF OSC to stabilize */
    while ((pADI_CLKG0_OSC->CTL & (1U << BITP_CLKG_OSC_CTL_LFOSCOK)) == 0u)
    /* set the power management interrupts when needed */
    /* compute new internal clocks based on the newly reset controller */
    return;
int main(void)
What am I doing wrong?
If I include system_ADuCM3029.c, I get a stack of 'multiply defined' variable errors
I have written thousands of lines of code for PICs, Atmels, 8051s etc, but am new to the ARM ecosystem.
Please let me know
Bill
  • FIRST IS DON'T INCLUDE THE C FILE!
    THEN DO INCLUDE THE PROPER HEADER FILE
    THIS IS NOT SPECIFIC TO ARM. IT WILL BE THE SAME FOR ANY SANE DEVELOPMENT ENVIRONMENT
  • Thanks for replying so quickly. The inclusion of the C file was an act of desperation.
    I found the problem - I had not configured the Run Time Environment (RTE) properly.
    For those who stumble across this post looking for advice on the same error, here is the solution:
    Inside Keil, do Project -> Manage -> Run Time Environment
    Check the following boxes:
    CMSIS -> Core
    Device -> Examples Support
    Device -> Global Configuration
    Device -> Retarget
    Device -> Startup
    Device -> Drivers -> UART
    Device -> Services -> DMA
    Device -> Services -> Power
    Device -> Services -> WDT
    There should then be no messages in the Validation Output box at the bottom
    of the Run Time Environment Window.
    Code works perfectly now. On to the next headache
