Hello!
Has anybody been able to run some sample programs with the Analog Devices ADuC7126 microcontroller? I am trying to write code for this device, but I keep getting the Flash Download Failed error when I try to transfer the code to the ADuC7126 board. I am getting the same problem with Keil Microvision 3 and Keil Microvision 5. I was going to try to use Keil Microvision 4, but I was not sure how to get it. Does anyone have any suggestions on how to resolve this problem?
Thanks!
It's an ARM7 based device: http://www.keil.com/dd/chip/6182.htm
You would need to download the legacy pack from below link (in case you are using MDKv5.xx): www2.keil.com/.../
This pack should contain the flash algorithm for this device
