ARM Compiler 6.7: bug in size optimization?
Source of main.cpp:
typedef void (* fun_t)( void );
static const fun_t fun = [] { for (;;); };
int main( void )
        fun();
Listing:
    Region$$Table$$Base
    Region$$Table$$Limit
    main
** Section #2 '.debug_frame' (SHT_PROGBITS)
Map file:
    Removing main.o(.text), (0 bytes).
    Removing main.o(.ARM.exidx.text.main), (8 bytes).
    Removing main.o(.ARM.use_no_argv), (4 bytes).
Why main function was removed?
  • It does nothing?
    It was in-lined as a " B . "
  • Listing:
        $d.1
        __arm_cp.0_0
            0x08000228:    40023800    .8.@    DCD    1073887232
        __arm_cp.0_1
            0x0800022c:    07405408    .T@.    DCD    121656328
        Region$$Table$$Base
        main
    ** Section #3 '.symtab' (SHT_SYMTAB)
        Size   : 2800 bytes (alignment 4)
        String table #4 '.strtab'
        Last local symbol no. 45
    ** Section #4 '.strtab' (SHT_STRTAB)
    ** Section #5 '.note' (SHT_NOTE)
        Size   : 20 bytes (alignment 4)
    ** Section #6 '.comment' (SHT_PROGBITS)
    ** Section #7 '.shstrtab' (SHT_STRTAB)
    ** Object/Image Component Sizes
          Code (inc. data)   RO Data    RW Data    ZI Data      Debug   Object Name
           168         32        392          0          0         68   _test.axf
           168         32        392          0          0          0   ROM Totals for _test.axf
    There is nothing.
    There is no main function!
    ARM Compiler version: 6.7 (clang)
    Optimization: -Oz
    Common options: --target=arm-arm-none-eabi -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -ffast-math -ffunction-sections -fdata-sections
    Additional compiler options: -std=gnu++11 -fno-rtti -fno-exceptions
    Additional linker options: --strict --scatter=$(SCRIPT) --symbols --list_mapping_symbols
  • Full listing. Part of the code has been removed to reduce the listing size.
    ** ELF Header Information
        File Name: _test.axf
        Machine class: ELFCLASS32 (32-bit)
        Data encoding: ELFDATA2LSB (Little endian)
        Header version: EV_CURRENT (Current version)
        Operating System ABI: none
        ABI Version: 0
        File Type: ET_EXEC (Executable) (2)
        Machine: EM_ARM (ARM)
        Image Entry point: 0x08000189
        Flags: EF_ARM_HASENTRY + EF_ARM_ABI_FLOAT_HARD (0x05000402)
        ARM ELF revision: 5 (ABI version 2)
        Conforms to Hard float procedure-call standard
        Built with
        Component: ARM Compiler 6.7 Tool: armlink [5c9ef700]
        Header size: 52 bytes (0x34)
        Program header entry size: 32 bytes (0x20)
        Section header entry size: 40 bytes (0x28)
        Program header entries: 1
        Section header entries: 8
        Program header offset: 7932 (0x00001efc)
        Section header offset: 7964 (0x00001f1c)
        Section header string table index: 7
    ** Program header #0 (PT_LOAD) [PF_X + PF_R + PF_ARM_ENTRY]
        Virtual address: 0x08000000 (Alignment 4)
    ** Section #1 'ROM' (SHT_PROGBITS) [SHF_ALLOC + SHF_EXECINSTR]
        Size   : 560 bytes (alignment 4)
        Address: 0x08000000
        $d.realdata
        vectors
            0x08000000:    20020000    ...     DCD    537001984
    REMOVED
            0x08000184:    080001cd    ....    DCD    134218189
        $t
        .ARM.Collect$$$$00000000
        .ARM.Collect$$$$00000001
        __main
        _main_stk
            0x08000188:    f8dfd018    ....    LDR      sp,__lit__00000000 ; [0x80001a4] = 0x20020000
        .ARM.Collect$$$$00000004
        _main_scatterload
            0x0800018c:    f000f80c    ....    BL       __scatterload ; 0x80001a8
        .ARM.Collect$$$$00000008
        .ARM.Collect$$$$0000000A
        .ARM.Collect$$$$0000000C
        __main_after_scatterload
        _main_clock
        _main_cpp_init
        _main_init
            0x08000190:    4801        .H      LDR      r0,[pc,#4] ; [0x8000198] = 0x80001a1
            0x08000192:    4686        .F      MOV      lr,r0
            0x08000194:    4801        .H      LDR      r0,[pc,#4] ; [0x800019c] = 0x8000231
            0x08000196:    4700        .G      BX       r0
        $d
            0x08000198:    080001a1    ....    DCD    134218145
            0x0800019c:    08000231    1...    DCD    134218289
        $t
        __rt_final
        .ARM.Collect$$$$0000000D
        .ARM.Collect$$$$00000010
        __rt_final_cpp
        __rt_final_exit
            0x080001a0:    f000f814    ....    BL       ADC_IRQHandler ; 0x80001cc
        $d
        .ARM.Collect$$$$00002712
        __lit__00000000
            0x080001a4:    20020000    ...     DCD    537001984
        $t
        .text
        __scatterload
        __scatterload_rt2
            0x080001a8:    4c06        .L      LDR      r4,[pc,#24] ; [0x80001c4] = 0x8000230
            0x080001aa:    4d07        .M      LDR      r5,[pc,#28] ; [0x80001c8] = 0x8000230
            0x080001ac:    e006        ..      B        0x80001bc ; __scatterload + 20
            0x080001ae:    68e0        .h      LDR      r0,[r4,#0xc]
            0x080001b0:    f0400301    @...    ORR      r3,r0,#1
            0x080001b4:    e8940007    ....    LDM      r4,{r0-r2}
            0x080001b8:    4798        .G      BLX      r3
            0x080001ba:    3410        .4      ADDS     r4,r4,#0x10
            0x080001bc:    42ac        .B      CMP      r4,r5
            0x080001be:    d3f6        ..      BCC      0x80001ae ; __scatterload + 6
            0x080001c0:    f7ffffe6    ....    BL       __main_after_scatterload ; 0x8000190
        $d
            0x080001c4:    08000230    0...    DCD    134218288
            0x080001c8:    08000230    0...    DCD    134218288
        $t.0
        ADC_IRQHandler
    REMOVED
        WWDG_IRQHandler
        _microlib_exit
            0x080001cc:    e7fe        ..      B        ADC_IRQHandler ; 0x80001cc
            0x080001ce:    0000        ..      MOVS     r0,r0
        Reset_Handler
            0x080001d0:    b580        ..      PUSH     {r7,lr}
            0x080001d2:    4804        .H      LDR      r0,[pc,#16] ; [0x80001e4] = 0xe000ed88
            0x080001d4:    f44f0170    O.p.    MOV      r1,#0xf00000
            0x080001d8:    6001        .'      STR      r1,[r0,#0]
            0x080001da:    f000f805    ....    BL       SystemInit ; 0x80001e8
            0x080001de:    f7ffffd3    ....    BL       __main ; 0x8000188
            0x080001e2:    bf00        ..      NOP
        $d.3
        __arm_cp.1_0
            0x080001e4:    e000ed88    ....    DCD    3758157192
        $t.0
        SystemInit
            0x080001e8:    480f        .H      LDR      r0,[pc,#60] ; [0x8000228] = 0x40023800
    REMOVED
            0x08000226:    4770        pG      BX       lr
        $d.1
        __arm_cp.0_0
        __arm_cp.0_1
        Region$$Table$$Base
        main
  • Ok, so some more opportunities for dead code removal, definitely seems larger than necessary.
    If foo uses a volatile loop variable it might distraction the compiler enough to keep it.
  • Code
    int main( void )
        fun();
    is equivalent to the code below
    int main( void )
        for (;;);
    So I think that main function has not dead code, it has infinite loop.
    The second version is compiled correctly.
        main
            0x08000230:    e7fe        ..      B        main ; 0x8000230
            0x08000232:    0000        ..      MOVS     r0,r0
    Is it bug of the compiler?
  • static const fun_t fun = [] { for (;;); };
    Yes, but ARM Compiler 5 and GCC 6.3.1 do it properly.
