I am having trouble finding a good source to help me set up printf debugging on my project. I am currently using the STM32F7xx series board with uVision and MXCUBE to initialize the project. Most of the sources I find are fairly old and do not seem to work. Is there an updated page I could look at to help me set it up? Thank you for your assistance!
Pretty sure the usual fputc() code works, you might need to enable access to the ITM registers.
community.st.com/.../147118-stm32f769i-disco-printf-using-itmswo
volatile uint32_t *ITM_LAR = (volatile uint32_t *)0xE0000FB0; // ITM->LAR *ITM_LAR = 0xC5ACCE55; // Enable Access
//**************************************************************************** // Hosting of stdio functionality through SWV - Serial Wire Viewer //**************************************************************************** #include <rt_misc.h> #pragma import(__use_no_semihosting_swi) struct __FILE { int handle; /* Add whatever you need here */ }; FILE __stdout; FILE __stdin; int fputc(int ch, FILE *f) { ITM_SendChar(ch); return(ch); } int fgetc(FILE *f) { char ch; ch = '?'; return((int)ch); } int ferror(FILE *f) { /* Your implementation of ferror */ return EOF; } void _ttywrch(int ch) { ITM_SendChar(ch); } void _sys_exit(int return_code) { label: goto label; /* endless loop */ } //****************************************************************************
