STM32F4 with Nand Flash by using RL-FlashFS in uVersion 5
Hi everyone,
I am studying on STM32F4 micro-processor driving nand flash with RL-FlashFS in Keil V5. I read a lot documents and webpages but they are most in Keil V4. However, I think Keil V5 changed a lot when using RL-FlashFS, not only no nand flash driver template but also no comprehensive document to tell which file needs to be added, which API needs to be built(Most searched result from Google are Keil V4). Maybe I missed those pages or not smart to understand the procedure from old document. I tried to use STMF2xx_NAND.c/.h files as template in Keil installed folder, but after compile, lots of definitions not found such as NAND_DRV_CFG. I don't know which header files or other c files I should add in.
Could anyone help me to show me any documents or webpage where instruct how to build nand flash driver with RL-FlashFS in Keil V5 step by step?
Thanks for your time and help.
Mark
  • MDK v5.x comes with Middleware pack concept.
    More details you can find here http://www.keil.com/pack/doc/mw/FileSystem/html/index.html
    There are also several example projects, like File_demo, available in Pack Installer of MDK you can take as a reference to understand using FS on NAND flash
  • Thanks for your help Chen.
    Actually I checked that webpage but not figured out what files do I need to add. I understand how to add configuration files like it shows in webpage, but when I tried to add drivers in, I got lots of compiling errors. Also I couldn't find proper example in MDK honestly, like there is one file system demo for MCBSTM32F400 from Keil, but if you look at deeply, you gona find in the project, it only has NAND Flash configuration files but no driver, no API, only has Nor Flash and SD card stuff. I know NAND Flash driver is a kind of commercial secret but at least I would like to know which file I need to add in, which API I should build like in MDK v4 help webpage, it is very clear.
    Anyway, thanks for your help again.
    Cheers
