Hi all,
How can i get vendorId and Productid of the usb connected. Which Api can be used from a middleware application?
From the link www.keil.com/.../_u_s_b__device__descriptor.html , i understood DEVICE DESCRIPTOR can be used.
But how this can be called in a function??
Regards Arun
http://www.keil.com/forum/62249 ?
Maybe if you explain what you're actually trying to achieve, people may be able to make informed suggestions?
www.catb.org/.../smart-questions.html
Ok.
Thanks for your suggestion.
So my question is how i can get vendorId and productId of the usb. it will be helpful if you could share a sample code.
Hi ,
I am using Keil-rtx and CMSIS driver for usb.
For STM32Cube driver ,i found following code which give Vendor Id and Product id of usb. Refernce Link: github.com/.../usbh_msc.c
///code for STM32 cube case MSC_READ_INQUIRY: scsi_status = USBH_MSC_SCSI_Inquiry(phost, MSC_Handle->current_lun, &MSC_Handle->unit[MSC_Handle->current_lun].inquiry); if( scsi_status == USBH_OK) { USBH_UsrLog ("Inquiry Vendor : %s", MSC_Handle->unit[MSC_Handle->current_lun].inquiry.vendor_id); USBH_UsrLog ("Inquiry Product : %s", MSC_Handle->unit[MSC_Handle->current_lun].inquiry.product_id); USBH_UsrLog ("Inquiry Version : %s", MSC_Handle->unit[MSC_Handle->current_lun].inquiry.revision_id); MSC_Handle->unit[MSC_Handle->current_lun].state = MSC_TEST_UNIT_READY; } if( scsi_status == USBH_FAIL) { MSC_Handle->unit[MSC_Handle->current_lun].state = MSC_REQUEST_SENSE; } else if(scsi_status == USBH_UNRECOVERED_ERROR) { MSC_Handle->unit[MSC_Handle->current_lun].state = MSC_IDLE; MSC_Handle->unit[MSC_Handle->current_lun].error = MSC_ERROR; } break;
but, since i am using CMSIS driver these functions are not provided. Is there any method to find usb details with CMSIS driver.
I got the soluton and is working fine .
Refer: http://www.keil.com/forum/62263/#/msg204058
