/** Advance Declaration **/ struct enreg; typedef enreg Ts_Enreg; /** Prototypes **/ extern unsigned char MyFunc_1( Ts_Enreg * objects ); extern unsigned char MyFunc_2( Ts_Enreg objects[]);
MyFunc_1 and MyFunc_2 prototypes are equivalent, but C251 raises an error C52: Use of undefined type 'enreg'.
Why ?
C251 version : v5.58.17.0
PS : There is a complete description of the structure 'enreg' in the program source.
Arnaud
That doesn't do what you believe it does. It relies on there being a typedefed or #defined type 'enreg' present, but there isn't. If your textbook claims this is supposed to work, you need a different one, because the one you have is not actually about the C programming language.
No, they're not. It's one thing to declare a function that takes an unknown type, but quite a different one if it takes a pointer to that unknown type.
