Ethernet Stop working
Hello
Here is my program
int main (void) {
        net_initialize();
        socket = tcp_get_socket (TCP_TYPE_SERVER, 0, 20, tcp_callback);
                if (socket) {
                tcp_listen (socket, 4050);
        if (tcp_check_send(socket) ){
        sprintf(msg,"W%04d%04d%04d%04d%04d%04d%04d%04d%05dR\n",10,20,30,40,50,60,70,80,90);
        len=sizeof(msg);
        sendbuf = tcp_get_buf (len);
        memcpy (sendbuf, msg, len);
        tcp_send (socket, sendbuf,len);
                                 osDelay (1000);
when I remove this par
        len=sizeof(msg);
I can't connect to chip via TCP/IP protocol but it shows only
W0010002000300040005000600070008000090R
and the do nothing but connection is alive.and when I add
        len=sizeof(msg);
I can't open the port and I fail to connect to my chip.
what is my mistake?
  • when I remove this part
            len=sizeof(msg);
    I can connect to my chip but it shows only
    for the once and do nothing.However in this statues connection is alive.(but send nothing more).In addition when I add the above code I can't open the port and I fail to connect to my chip.
    what is my mistake?
  • Sorry I pasted badly
    int main (void) {
            net_initialize();
                    if (socket) {
                    while (1)
                     net_main();
            len=sizeof(msg);
                                     osDelay (1000);
  • Try calling tcp_get_state() before tcp_check_send(). Maybe socket is in state TCP_STATE_LISTEN, instead of TCP_STATE_CONNECT(ed). This may also help you with the other issue posted:
    http://www.keil.com/forum/61112/
    You are using network component v5/v6. Using the network's debug may help resolve issue:
    www.keil.com/.../network_create_app.html
    In the newest version (v7), netTCP_Send returns netStatus, which is more informative than tcp_send's boolean.
  • Dear Zack
    Thank you for your explanation
    I change my network component to V7 beta but in this states with this new code and other settings(Such as SPI and IP) I can't ping device's IP
    #include "cmsis_os.h"
    #include "rl_net.h"
    uint32_t sock;
    uint32_t Tcp_Stat(int32_t socket, netTCP_Event event, const NET_ADDR *addr, const uint8_t *buf, uint32_t len) ;
    int main (void) {
            netInitialize ();
            sock = netTCP_GetSocket (Tcp_Stat);
            netTCP_SetOption (sock, netTCP_OptionTOS, 30);
                    if (sock >=0) {
                    netTCP_Listen (sock, 2000);
                    while (1)
    uint32_t Tcp_Stat(int32_t socket, netTCP_Event event, const NET_ADDR *addr, const uint8_t *buf, uint32_t len) {
      switch (event) {
        case netTCP_EventConnect:return (1);
        case netTCP_EventEstablished:break;
        case netTCP_EventClosed :break;
        case netTCP_EventAborted:break;
        case netTCP_EventACK :break;
        case netTCP_EventData:break;
      return (0);
    what is my mistake?
  • What version of the Networking middleware are you using?
  • Please download the active version "Keil.MDK-Middleware.7.0.0.pack".
    The beta version is actually older (I know that it is listed above).
  • Dear Reinhard Keil
    Thank you
    now I'm downloading MDK V7.
    But I find my problem but it is too strange.
    when I use sprintf without any variables with any size of string it works fine.
    sprintf(msg,"HHHHHHHHHHellllooooooooooooooooo");
    but as I add a little size variable to this command it doesn't work properly and I lose my connectivity or even it doesn't bind any port to my IP.
    sprintf(msg,"W%04dR",10);
    sprintf(msg,"W%04dR",var);
    what do you think about this problem?
  • Hello
    I download the MDK v7.0 but ping command (in my pc) can't detect my board IP.My all configs are the same as the old ones ( with MDK v6.5) but it doesn't do anything.
    int main (void) {
            netInitialize ();
            netTCP_SetOption (sock,netTCP_OptionTimeout, 120);
                    if (sock >=0) {
                    netTCP_Listen (sock, 4050);
            while(1){}
      switch (event) {
      return (0);
    should I do anything else?
