LPC1788 EEPROM
Dear all,
I hope everything is fine with you.
Anybody has an example which demonstrates how to use LPC1788's EEPROM?
I have written the following code in C++ and it does not work, I am wondering what the problem might be:
#include "LPC177x_8x.h"                 // Device header
unsigned int x = 0;
int main()
        LPC_EEPROM->CLKDIV = 319;
        LPC_EEPROM->WSTATE = (1<<0)|(6<<8)|(4<<16);
        LPC_EEPROM->INT_SET_ENABLE = 1<<26;            // Enable write operation finished interrupt
        NVIC_EnableIRQ(EEPROM_IRQn);
        LPC_EEPROM->ADDR = 0x40;                     // ********************
        LPC_EEPROM->CMD = 0x05;                              // 32 bit write command
        LPC_EEPROM->WDATA = 0x15;
        while(1);
void EEPROM_IRQHandler()
        LPC_EEPROM->INT_CLR_STATUS = 1<<26;    // Clear interrupt flag
        x = 10;
Best regards
  • Hi,
    I know it's a bit late to post an answer, but I hope my answer will be useful for other people. I've put my example just in the end of this post. Please always refer to the NXP LPC17xx user manual (the one I use is named UM10470)
    With your values, I assume you are running the sysclock @ 120MHz. Be sure that your sysclock is running at 120MHz. Without any clock initialisation, I'm not sure if the CPU run at this speed by default.
    CLKDIV
    This value should be set accordingly with your sysclock. I highly recommend to setup all the internal clocks correctly before doing anything else.
    EEWSTATE
    If your sysclock is running @ 120MHz, your values are correct. Be sure you are running at 120MHz
    Interrupt registers
    The User Manual says :
    The interrupt request output is asserted when the bitwise AND of STAT and INTEN is
    nonzero. For the EEPROM read/write operation finished interrupt it is betters not to enable
    the interrupt, but to only poll the bit in the STAT register. This is because these
    operations are relatively fast operations that do not justify calling a interrupt service
    subroutine in software.
    So I think you should not use the interrupt service subroutine. I poll the STAT register and everything works fine for me.
    ****** THIS CODE IS RUNNING WITH EWARM of IAR EMBEDED WORBENCH ******
    #define kEEPROM_END_OF_RW       (Int32U) 0x1<<26
    #define kEEPROM_END_OF_PROG      (Int32U) 0x1<<28
    void iEEPROM_setup(){
      //Enable power (disable power down)
      EEPWRDWN_bit.PWRDWN = 0;
      //Set the wait state register
      EEWSTATE_bit.PHASE3 = 1; //96'000'000Hz ~= 10ns period, 15ns = 1x10ns + 10ns
      EEWSTATE_bit.PHASE2 = 5; //55ns = 5x10ns + 10ns
      EEWSTATE_bit.PHASE1 = 3; //35ns = 3x10ns + 10ns
      //Set clock preescaler to reach a 375 kHz clock
      //Th processor clock currently runs at 96 MHz
      // preescaler = (96 000 000 / 375 000) - 1
      EECLKDIV_bit.CLKDIV = 255;
      //disable the interrupt (recommended by NXP)
      EEINTENCLR = kEEPROM_END_OF_RW || kEEPROM_END_OF_PROG;
      EEINTSTATSET = kEEPROM_END_OF_RW || kEEPROM_END_OF_PROG;
      //The EEPROM is now ready to receive commands
    Hope this will help
