Branch to application from bootloader
Hi, I am using this function to branch to application wo problems on GNU tools:
static void boot_jump(uint32_t lAddress) {
  __asm(
      "LDR SP, [R0]\n"
      "LDR PC, [R0, #4]\n"
But compiling in MDK-ARM reports:
bootloader.c(45): error: #20: identifier "SP" is undefined
How to solve this or what method must be used in MDK-ARM to do the same?
I could not find any bootloader example in the Keil pack that comes for STM32F micro.
  • Solution is:
      typedef  void (*pFunction)(void);
      pFunction jumpToApplication = (pFunction) lAddress;
      /* Initialize user application's Stack Pointer */
      __set_MSP(*(__IO uint32_t*) lAddress);
      jumpToApplication();
    Found the example elsewhere.
  • Sorry correct code is:
    static void boot_jump(uint32_t address) {
      pFunction jumpToApplication = (pFunction) *(__IO uint32_t*)(address + 4);
      __set_MSP(*(__IO uint32_t*) address);
