Writing any thing to UART register cause hard fault
Hello, I am using tm4c123g microcontroller(cortex m4) and successfully programmed led blink, created 16x2 and 128x64 library files using CMSIS standard.
But when I try to write any value in UART register, it causes the cpu to jump into hard fault.
Example
UART0->CTL&=~1;
triggers the hard fault handler.
I am facing this problem with all other UART registers like baud registers.
BTW I am able to do it with direct memory addressing. But I want to use UART funcions in CMSIS.
I don't know what's going wrong please help.
  • Thanks for reply.I tried to debug that fault but still got nothing.The initialization rituals are given in the datasheet and i am following in the same manner.When i write the values using CMSIS standard it triggers the hard fault, but when i use direct memory addressing in the same manner it works fine.So in my opinion it is not something related to unlocking or clocking the IO.
    BTW I am going to ask TI too.
