How printf function can sends a data using UART?
Hi ,
I'm working on FlashFs example for mcb1700 and can run it on my board but i couldn't understand how printf function can send a string to RS232 using UART0 of lpc1768. I read another thread that one asked a similar question on C51 and a person said that printf function calls putchar() and we should modify putchar function to send the string to another UART but the question is this:
however i know that i can modify SER_int()in serial.c for changing the UART port to UART3 or so on.
How the printf function can communicate with SER_getChar()in serial.c file to send a string to serial port?
for example how the following code sends the string to RS232 ic with UART0?
printf("\nRead data from file %s\n",fname);
i couldn't find the source code in program.
thanks.
  • You supply the hosting functions for fputc(),fgetc(),_ttywrch(),etc to support the STDIO functions, and the printf(),scanf() type functions decompose into calls to said functions
  • Can you tell me what will happen step by step when following code is written on FLashFS program:
    printf ("\nFile closed.\n");
    suppose that i have modified serial.c file as below:
    int SER_putChar (int uart, int c) {
      LPC_UART_TypeDef *pUart;
      pUart = (uart == 0) ? (LPC_UART_TypeDef *)LPC_UART0 : (LPC_UART_TypeDef *)LPC_UART1;
      while (!(pUart->LSR & 0x20));
      return (pUart->THR = c);
      Read character from Serial Port   (blocking read)
    int SER_getChar (int uart) {
      while (!(pUart->LSR & 0x01));
      return (pUart->RBR);
      Read character from Serial Port   (non blocking read)
    int SER_getChar_nb (int uart) {
      if (pUart->LSR & 0x01)
      else
        return 0;
      Write character to Serial Port
    void SER_putString (int uart, unsigned char *s) {
      while (*s != 0) {
       SER_putChar(uart, *s++);
    and my retarget.c functions are as below
    #define STDIN   0x8001
    #define STDOUT  0x8002
    #define STDERR  0x8003
    /* Standard IO device name defines. */
    const char __stdin_name[]  = "STDIN";
    const char __stdout_name[] = "STDOUT";
    const char __stderr_name[] = "STDERR";
    struct __FILE { int handle; /* Add whatever you need here */ };
    #ifdef STDIO
    int sendchar (int c) {
      if (c == '\n')  {
        SER_putChar (1, 0x0D);
      SER_putChar (1, c);
      return (c);
    int getkey (void) {
      return (SER_getChar(1));
    #endif
    /*--------------------------- _ttywrch --------------------------------------*/
    void _ttywrch (int ch) {
    #ifdef STDIO
      sendchar(ch);
    #endif
    /*--------------------------- _sys_open -------------------------------------*/
    FILEHANDLE _sys_open (const char *name, int openmode) {
      /* Register standard Input Output devices. */
      if (strcmp(name, "STDIN") == 0) {
        return (STDIN);
      if (strcmp(name, "STDOUT") == 0) {
        return (STDOUT);
      if (strcmp(name, "STDERR") == 0) {
        return (STDERR);
      return (__fopen (name, openmode));
    /*--------------------------- _sys_close ------------------------------------*/
    int _sys_close (FILEHANDLE fh) {
      if (fh > 0x8000) {
        return (0);
      return (__fclose (fh));
    /*--------------------------- _sys_write ------------------------------------*/
    int _sys_write (FILEHANDLE fh, const U8 *buf, U32 len, int mode) {
    #ifdef STDIO
      if (fh == STDOUT) {
        /* Standard Output device. */
        for (  ; len; len--) {
          sendchar (*buf++);
        return (0);
    #endif
      if (fh > 0x8000) {
        return (-1);
      return (__write (fh, buf, len));
    /*--------------------------- _sys_read -------------------------------------*/
    int _sys_read (FILEHANDLE fh, U8 *buf, U32 len, int mode) {
    #ifdef STDIO
      if (fh == STDIN) {
        /* Standard Input device. */
          *buf++ = getkey ();
        return (0);
    #endif
      if (fh > 0x8000) {
        return (-1);
      return (__read (fh, buf, len));
    /*--------------------------- _sys_istty ------------------------------------*/
    int _sys_istty (FILEHANDLE fh) {
      if (fh > 0x8000) {
        return (1);
      return (0);
    /*--------------------------- _sys_seek -------------------------------------*/
    int _sys_seek (FILEHANDLE fh, long pos) {
      if (fh > 0x8000) {
        return (-1);
      return (__setfpos (fh, pos));
    /*--------------------------- _sys_ensure -----------------------------------*/
    int _sys_ensure (FILEHANDLE fh) {
      if (fh > 0x8000) {
        return (-1);
      return (__flushbuf (fh));
    /*--------------------------- _sys_flen -------------------------------------*/
    long _sys_flen (FILEHANDLE fh) {
      if (fh > 0x8000) {
        return (0);
      return (__get_flen (fh));
    /*--------------------------- _sys_tmpnam -----------------------------------*/
    int _sys_tmpnam (char *name, int sig, unsigned maxlen) {
      return (1);
    /*--------------------------- _sys_command_string ---------------------------*/
    char *_sys_command_string (char *cmd, int len) {
      return (cmd);
    /*--------------------------- _sys_exit -------------------------------------*/
    void _sys_exit (int return_code) {
      /* Endless loop. */
      while (1);
  • suppose that i have modified serial.c file as below:
    int SER_putChar (int uart, int c) { LPC_UART_TypeDef *pUart;
    pUart = (uart == 0) ? (LPC_UART_TypeDef *)LPC_UART0 : (LPC_UART_TypeDef *)LPC_UART1; while (!(pUart->LSR & 0x20)); return (pUart->THR = c);
    /*---------------------------------------------------------------------------- Read character from Serial Port (blocking read) *----------------------------------------------------------------------------*/
    int SER_getChar (int uart) { LPC_UART_TypeDef *pUart;
    pUart = (uart == 0) ? (LPC_UART_TypeDef *)LPC_UART0 : (LPC_UART_TypeDef *)LPC_UART1; while (!(pUart->LSR & 0x01)); return (pUart->RBR);
    /*---------------------------------------------------------------------------- Read character from Serial Port (non blocking read) *----------------------------------------------------------------------------*/
    int SER_getChar_nb (int uart) { LPC_UART_TypeDef *pUart;
    pUart = (uart == 0) ? (LPC_UART_TypeDef *)LPC_UART0 : (LPC_UART_TypeDef *)LPC_UART1; if (pUart->LSR & 0x01) return (pUart->RBR); else return 0;
    /*---------------------------------------------------------------------------- Write character to Serial Port *----------------------------------------------------------------------------*/
    while (*s != 0) { SER_putChar(uart, *s++); }
    #ifdef STDIO
    if (c == '\n') { SER_putChar (1, 0x0D); } SER_putChar (1, c);
    return (c);
    int getkey (void) {
    } #endif
    #ifdef STDIO sendchar(ch);
    #endif
    FILEHANDLE _sys_open (const char *name, int openmode) { /* Register standard Input Output devices. */ if (strcmp(name, "STDIN") == 0) { return (STDIN); } if (strcmp(name, "STDOUT") == 0) { return (STDOUT); } if (strcmp(name, "STDERR") == 0) { return (STDERR); } return (__fopen (name, openmode));
    int _sys_close (FILEHANDLE fh) { if (fh > 0x8000) { return (0); } return (__fclose (fh));
    #ifdef STDIO if (fh == STDOUT) { /* Standard Output device. */ for ( ; len; len--) { sendchar (*buf++); } return (0); }
    #endif if (fh > 0x8000) { return (-1); } return (__write (fh, buf, len));
    #ifdef STDIO if (fh == STDIN) { /* Standard Input device. */ for ( ; len; len--) { *buf++ = getkey (); } return (0); }
    #endif if (fh > 0x8000) { return (-1); } return (__read (fh, buf, len));
    int _sys_istty (FILEHANDLE fh) { if (fh > 0x8000) { return (1); } return (0);
    int _sys_seek (FILEHANDLE fh, long pos) { if (fh > 0x8000) { return (-1); } return (__setfpos (fh, pos));
    int _sys_ensure (FILEHANDLE fh) { if (fh > 0x8000) { return (-1); } return (__flushbuf (fh));
    long _sys_flen (FILEHANDLE fh) { if (fh > 0x8000) { return (0); } return (__get_flen (fh));
    int _sys_tmpnam (char *name, int sig, unsigned maxlen) { return (1);
    char *_sys_command_string (char *cmd, int len) { return (cmd);
    void _sys_exit (int return_code) { /* Endless loop. */ while (1);
  • For characters in formatted string _sys_write -> sendchar -> SER_putChar
    Which you could presumably test at the various levels and confirm if characters emit from the USART
    In uv4 I've generally just done this hosting stuff at the sendchar() level
    Suggest you break out the debugger, break point and step-by-step the code if you need that level of understanding.
