I have a problem when i am building my project in KEIL v4.60 for target LPC2148. i am getting following errors: voice.axf: Warning: L6310W: Unable to find ARM libraries. voice.axf: Error: L6411E: No compatible library exists with a definition of startup symbol __main.
i am getting this error even when i build KEIL Example projects also. Please some one tell me why this error is popping up? and in order to correct what should i do?
Previously I was using KEIL v3 after complete uninstallation ever deleting the registries i have installed KEIL 4.60 it got succussfully installed. is it a problem with installation? Even i thought this is a installation issue, so i have downloaded again installed it twice. still the issue is not resolved
i have this problem too,and i have instaled keil correctly
Then I guess I'd look at the project setting with respect to the linker, and the LIB environment variable(s) the linker might be using to find the correct libraries.
If you're a licensed user, then contact support.
This error will arise due to the missing of armlib folder in the following location "C:\Keil\ARM\RV31\LIB". Check once your system drive. if this not available,update that folder from keil website, Then you will get clerance.
If you used to install an ADS software, then you need to remove the ADS software first. Then remember to clear the ADS path, e.g. d:\Program Files\ARM\ADSv1_2\bin, in the "Path" variable in your system environment variables.
I have just fixed the same problem with this method.
