Dear all,
I'm using the LPC2468 with SDRAM that ist configured in the startup and ind the memory layout. In general ist works. But I found one strange problem.
I have a sructure ExternalCFG that is in SDRAM (start adress at 0XA0000280). This structue has a value (ExternalCFG.ulMinCycleTime) that I want to check for zero:
if(DT50_tExternalCFG.ulMinCycleTime == 0)
this results in the following disassembly:
485: if(ExternalCFG.ulMinCycleTime == 0) 486: { 0x00004738 E51F0068 LDR R0,[PC,#-0x0068] 0x0000473C EB008F45 BL __rt_uread4(0x00028458) 0x00004740 E3500000 CMP R0,#0x00000000 0x00004744 1A000002 BNE 0x00004754
And know I jump to the __rt_uread4 that results tis dissambly:
0x00028458 E5D02001 LDRB R2,[R0,#0x0001] 0x0002845C E5D01000 LDRB R1,[R0] 0x00028460 E5D03002 LDRB R3,[R0,#0x0002] 0x00028464 E5D00003 LDRB R0,[R0,#0x0003] 0x00028468 E1811402 ORR R1,R1,R2,LSL #8 0x0002846C E1811803 ORR R1,R1,R3,LSL #16 0x00028470 E1810C00 ORR R0,R1,R0,LSL #24 0x00028474 E12FFF1E BX R14
When I know execute the last line (BX R14) my hole system crashes and no jtag possible. The value in R14 is the right return adress.
So what can be the problem???
Big thanks for the help,
Christian
If it happens while debugging try to switch to disassemby view and then single step on BX R14 instruction
