I'm not succeeding in accessing memory through pointers with the 24bit contiguous DS80C400 memory model. I've looked at the support doc http://www.keil.com/support/docs/2172.htm and tried adding a pointer to an absolute address (see line between //~ below code), this fails to compile.
#include "rom400_init.h" #include <stdio.h> // leave 4000h bytes for function parameters #define RAM_START 0x14000 #define RAM_END 0x5FFFF void main() { //~+GJE unsigned char far my_array[0x10] _at_ 0x400000; //~-GJE printf("DS80C400 Template Project\r\n"); init_rom(RAM_START, RAM_END); // let's print out a little version information... printf("DS80C400 Initialization Library Version %d\r\n", init_version()); while(1) { } }
Other methods of declaring & accessing a pointer are all not producing expected results for me, have tried FVAR() and FCVAR() access macros, far, etc, eg
unsigned char const far * pROM ; pROM = (unsigned char const far *) 0x400002 ; for(i=0;i<4;i++){printf("%02bx",*pROM); pROM++;}
should print ASCII for "TINI" (that's the code execution tag ID thing for the TINI bootloader to find) but doesn't, showing
DS80C400 Template Project DS80C400 Silicon Software - Copyright (C) 2002 Maxim Integrated Products S/N: 445E700A91964189 MAC ID: 0060350975F6 DS80C400 Initialization Library Version 19 00460240
instead. Am sure I'm missing something...
Have been following the instructions for project setup in Dallas AN613 and the C_library examples from the ftp.dalsemi.com/.../index.html site.
Meantime I'll have to crack on with also understanding Java code on this thing!
thanks in advance greg
oh, yes, current PK51 toolchain (ie C51 v8.16, AX51 v3.06a, LX51 v4.34a). DS80C400 target set to use LX51 & AX51, 'far' memory type support, multiple DPTRs
