should i config startup.a51 or do u have some steps to follow thx Jason
You may take a look at.: http://www.keil.com/support/docs/1296.htm It may or may not be required to change startup.a51, it depends on what you are trying to do... UVision 2 Getting start with ( Manual ) should also give you information on setting XDATA memory range. Alex
