When running hardfloat mgddaemon executable in a Raspberry Pi, I get "Illegal instruction".
Info:pi@rpi1:~ $ dpkg --print-architecturearmhf
pi@rpi1:~ $ cat /proc/cpuinfo processor : 0model name : ARMv6-compatible processor rev 7 (v6l)BogoMIPS : 697.95Features : half thumb fastmult vfp edsp java tls CPU implementer : 0x41CPU architecture: 7CPU variant : 0x0CPU part : 0xb76CPU revision : 7
Hardware : BCM2835Revision : 000e
Even if you get the Daemon running, I suspect you get stuck because the interceptor libraries MGD needs require a Mali GPU (the RPi uses a Broadcom VideoCore) and either an ARMv7 or ARMv8 CPU.
HTH,
Pete
Oh yeah sorry! I don't know why I did stuck believing that RPi was running a Mali GPU!Thanks for the info,Loukas
Hi Loukas,I think the biggest problem you have is that MGD interceptor is only delivered for ARMv7 and ARMv8 platforms the Raspberry Pi 1 is based on the ARM 11 CPU which is an ARMv6 CPU. This is probably why you get an illegal instruction exception the daemon is trying to run V7 instructions on a V6 processor.Hope this helps,
Stephen
