ASTC encoder options for single channel (luminance) textures
what would be the best/correct way to encode a single-channel luminance texture with the astc-encoder ? Since encoding time is important I would like to give this "hint" to the encoder instead of searching color endpoint modes (single plane, two-color mode ?).
Thanks.
  • Hi Steve_,
    The astcenc command-line tool doesn't support an option to specify the number of channels of the input texture. KTX and DDS formats support the definition of single-channel luminance texture and the astcenc tool can use them so maybe using these formats can speed up the conversions.
    For the compression quality I suggest you try to use the "-mask" option which makes all the channels of the input texture be unrelated to each other. In this way you should be able to combine multiple unrelated textures into a single one and compress them together. This will also improve performance since you will read just one texture instead of multiple ones.
    Regards,
    Daniele
