Overhead generated by calling clCreateBuffer
Hi everyone,
I'm using OpenCL on an Exynos 8890 Octacore CPU with ARM Mali-T880 MP12 GPU (Samsung S7 edge). And it is taking a high overhead when creating a buffer from the call clCreateBuffer. I'd like to know more about this issue. Is anything related with the driver that takes all this time? Why it takes a long time to create the buffer?
Below are described the example used and the sizes with their respective time. Observe that I'm creating two buffer each one with size of N*N elements of type float.
    #define DATA_TYPE float
    int N = 8192;
    t_start = rtclock();
#ifdef OFFLOAD
    a_mem_obj = clCreateBuffer(clGPUContext, CL_MEM_READ_ONLY, sizeof(DATA_TYPE) * N * N, NULL, &errcode);
    b_mem_obj = clCreateBuffer(clGPUContext, CL_MEM_READ_WRITE, sizeof(DATA_TYPE) * N * N, NULL, &errcode);
#else
    a_mem_obj = clCreateBuffer(clGPUContext, CL_MEM_READ_ONLY | CL_MEM_ALLOC_HOST_PTR,  sizeof(DATA_TYPE) * N * N, NULL, &errcode);
    b_mem_obj = clCreateBuffer(clGPUContext, CL_MEM_READ_WRITE | CL_MEM_ALLOC_HOST_PTR, sizeof(DATA_TYPE) * N * N, NULL, &errcode);
#endif
    t_end = rtclock();
    printf("Total time of clCreateBuffer %lf \n" , t_end - t_start);
N (size) clCreateBuffer (seconds)
2048 0.010235
4096 0.251183
8192 1.385209
9000 1.622948
10000 2.054119
11000 2.501804
PD. Executing the same program on an Intel GPU doesn't take a long time when compared with the time taken by Mali GPU.
Thanks!!!
