I work with a Unity3d project, on a non-rooted device.The libMGD.so is added and the Java Code is edited following the reference doc.
The MGD Daemon successfully find my test.apk in it's list.
I start MGD on my PC and connect successfully.
However the capturing target get nothing.
The logcat get some error:
01-07 07:07:13.109: E/libMGD(21679): Can't open /data/__lzftmp__ (deleted)
01-07 07:07:13.109: E/libMGD(21679): Reason: No such file or directory
01-07 07:07:13.109: E/libMGD(21679): Failed to parse process mappings.
My device is Huawei HONOR H30-L01M with Android 4.4.2.
Thank you for HELP!
Hi Foreverml,
Sorry to hear that you hare having trouble with MGD. Could you please provide your entire logcat from the start of the application so that we can best diagnose your issue? Would you also be able to tell us what version of MGD you are using?
Kind regards,
Stephen
