Both devices are using the same GPU design, but ARM only provides the logical design, not a fixed silicon layout. Our partners may choose very different implementation options to balance silicon area, performance, and energy efficiency. For example, choosing a different silicon process node, transistor choice, top frequency, power management options, memory system performance, cache size, etc.
In addition there may be software changes; i.e. are both devices using the same version of the graphics drivers, or the same version of the host OS?
the difference is very large for the same of GPU(it even 4 000 pkt). This unit is exynos 5430 so the same, and the results are very different.
Generally arm mali T628 mp6 has worse results in 3dmark ice strom ultimited. Why?
