Greetings,
I'm currently experimenting OpenGL ES 2.0 with a little tile based 2D game.
After fiddling a bit with rbga5551 transparent textures, I found I had to enable blending in order to make the last transparency bit work.
However, given how blending works and the fact I only need binary transparency (1 bit for alpha → visible/invisible), I'm wondering if it would be better to either :
Since I do not know how to micro-benchmark and measure performance¹ of embedded OpenGL programs, I'm asking this question here :
For binary transparency (visible/invisible) is it better to clip (vertex shader), discard (fragment shader) or just enable blending (rasterisation)
¹ : I tried to use Streamline but I could not install gator since I do not have the kernel sources of either my two Rockchip tablets, nor the kernel sources of my Kirin-based Honor 5 phone.
This might be worth a read in terms of actually getting some performance benefit out of the 3D hardware:
Mali Performance 7: Accelerating 2D rendering using OpenGL ES
If you really want to stick to a simple back-to-front render sequence then use clipping to coarsely get rid of parts which are not visible, and then just use blending for the rest - but this can leave quite a bit of performance on the table.
HTH, Pete
Interesting read.
If I understand your article correctly, given a character sprite with transparency, a tiled-level with transparent tiles and a background, I should :
If I associate clipped coordinates (one-time operation) to the transparent tiles of the level, will it be slightly better or worse ?
