mali emulator 2.3 mali-cube error on debian
I have installed the mali emulator 2.3 on my debian 8 system.
When I run the mali-cube example this is the error i get. I am new to the emulator and graphics and hence unaware of why this error comes.
how can i fix this problem.
Error below:
mali-cube
FATAL - Exception thrown in GLES31Api::glActiveTexture -> FATAL: No EGL context available for type GLES31Api when calling glActiveTexture
FATAL - Exception thrown in GLES31Api::glGetString -> FATAL: No EGL context available for type GLES31Api when calling glGetString
FATAL - Exception thrown in GLES31Api::glGetError -> FATAL: No EGL context available for type GLES31Api when calling glGetError
Running: (null)
FATAL - Exception thrown in GLES31Api::glCreateShader -> FATAL: No EGL context available for type GLES31Api when calling glCreateShader
FATAL - Exception thrown in GLES31Api::glShaderSource -> FATAL: No EGL context available for type GLES31Api when calling glShaderSource
FATAL - Exception thrown in GLES31Api::glCompileShader -> FATAL: No EGL context available for type GLES31Api when calling glCompileShader
FATAL - Exception thrown in GLES31Api::glGetShaderiv -> FATAL: No EGL context available for type GLES31Api when calling glGetShaderiv
FATAL - Exception thrown in GLES31Api::glGetShaderSource -> FATAL: No EGL context available for type GLES31Api when calling glGetShaderSource
Debug source START:
Debug source END
FATAL - Exception thrown in GLES31Api::glGetShaderInfoLog -> FATAL: No EGL context available for type GLES31Api when calling glGetShaderInfoLog
Log START:
Log END
Compilation failed.
To give the diagnostics of my PC, i ran the cube-checker application.
This is the output highlights from the same:
Created At:
2016-01-08T18:00:40Z
Emulator Version:
2.3.0
Operating System:
Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt20-1+deb8u1 (2015-12-14) x86_64
--moc
Shader compiler found: Mali Compiler Manager v3.1.0
--gl
OpenGL Vendor: Intel Open Source Technology Center
OpenGL Renderer: Mesa DRI Intel(R) Haswell Mobile
OpenGL Version: 3.0 Mesa 10.3.2
--environment
PATH=/usr/local/bin: /usr/bin: /bin: /usr/local/games: /usr/games
MALI_EMULATOR_COMPILER_MANAGER_PATH=/usr/lib/mali-opengl-es-emulator/openglessl/
LD_LIBRARY_PATH=/usr/lib/mali-opengl-es-emulator
--gles-and-egl
Loaded /usr/lib/mali-opengl-es-emulator/libEGL.so
Loaded /usr/lib/mali-opengl-es-emulator/libGLESv2.so
Regards
Yogesh
  • Hi yogk,
    Based on the information provided, this would be my first guess as to the problem:
    User Guide:
    In general, the Mali OpenGL ES Emulator will work on any system that supports at least:
    • OpenGL 3.2 – when OpenGL ES 2.0 contexts are used
    • OpenGL 3.3 – when OpenGL ES 3.0 contexts are used
    • OpenGL 4.3 – when OpenGL ES 3.1 contexts are used
    On all systems, up-to-date operating system components and graphics drivers are recommended.
    Your Graphics card:
    --gl
    Your Graphics card seems to only support OpenGL 3.0.
    As such, you cannot emulate OpenGL ES 2, 3 or 3.1 contexts, and that is the problem you are seeing.
    The way to resolve this is first to look online to see if the hardware you have can run a later OpenGL version, and if that is the case, update your drivers and try again.
    However if your hardware does not support this, then you will need to look at alternative hardware to run the emulator on.
    I hope this helps.
    Kind Regards,
    Michael McGeagh
