I have to install mali r5p2 driver on radxa rock pro board.
i had successfully build kernel and user space driver.
but i am getting the following error:
MALI PHYSICAL RANGE VALIDATION ERROR:
the range supply was: phys_base=0x97000000, size=0x007E9000
bind externel buf failed
_mali_ukk_mem_bind, return ERROR
i had build user space driver with ump support for Android kitkat.
how can i make it work?
Thank you.
Hi mohit28,
Considering you are stating you can build the user space driver, this must mean you have access to our proprietary DDK.
This means you are most likely a partner of ARM and are thus entitled to dedicated support.
Please contact ARM Support for this as we cannot discuss non-public information on the public community.
Kind Regards,
Michael McGeagh
