Streamline does not show "Mali GPU Utilization"
Hi Arm Team,
I am trying to profile an executable on android and followed the following article for using the gatord.
https://developer.arm.com/documentation/101813/0904/Application-profiling/Profile-executable-and-linkable-format-binaries-on-Android?lang=en
I used the attached configuration.xml, "gatord -o streamline-gatord-capture-svm-3d-with-configuration-xml.apc -c /system/svm-3d/configuration.xml -A /system/svm-3d/mbb_op"
<?xml version="1.0" encoding="UTF-8"?>
<configurations revision="3">
    <configuration counter="ftrace_power_cpu_idle" />
    <configuration counter="ftrace_block_block_rq_issue" />
    <configuration counter="ftrace_block_block_rq_complete" />
    <configuration counter="ftrace_power_clock_set_rate" />
    <configuration counter="ftrace_f2fs_f2fs_write" />
    <configuration counter="ftrace_ext4_ext4_da_write" />
    <configuration counter="ftrace_kmem_kmalloc" />
    <configuration counter="PERF_COUNT_SW_EMULATION_FAULTS" />
    <configuration counter="PERF_COUNT_SW_ALIGNMENT_FAULTS" />
    <configuration counter="PERF_COUNT_SW_PAGE_FAULTS_MIN" />
    <configuration counter="PERF_COUNT_SW_PAGE_FAULTS_MAJ" />
    <configuration counter="PERF_COUNT_SW_PAGE_FAULTS" />
    <configuration counter="PERF_COUNT_SW_CPU_MIGRATIONS" />
    <configuration counter="PERF_COUNT_SW_CONTEXT_SWITCHES" />
    <configuration counter="PERF_COUNT_SW_TASK_CLOCK" />
    <configuration counter="PERF_COUNT_SW_CPU_CLOCK" />
    <configuration counter="ARMv8_Cortex_A55_user" />
    <configuration counter="ARMv8_Cortex_A55_system" />
    <configuration counter="ARMv8_Cortex_A78_user" />
    <configuration counter="ARMv8_Cortex_A78_system" />
    <configuration counter="Linux_cpu_wait_io" />
    <configuration counter="Linux_cpu_wait_contention" />
    <configuration counter="ARMv8_Cortex_A55_switch" />
    <configuration counter="ARMv8_Cortex_A78_switch" />
    <configuration counter="ARMv8_Cortex_A55_irq" />
    <configuration counter="ARMv8_Cortex_A78_irq" />
    <configuration counter="ARMv8_Cortex_A55_softirq" />
    <configuration counter="ARMv8_Cortex_A78_softirq" />
    <configuration counter="ARMv8_Cortex_A55_metric_store_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_store_ls_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_simd_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_scalar_fp_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_retired_insns_percent" />
    <configuration counter="ARMv8_Cortex_A55_metric_load_store_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_load_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_load_ls_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_ll_cache_read_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_ll_cache_read_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_ll_cache_read_hit_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_l2d_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_l2_tlb_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_l2_tlb_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_l2_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_l1i_tlb_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_l1i_tlb_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_l1i_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_l1i_cache_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_l1d_tlb_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_l1d_tlb_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_l1d_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_l1d_cache_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_itlb_walk_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_itlb_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_ipc" />
    <configuration counter="ARMv8_Cortex_A55_metric_integer_dp_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_frontend_stalled_cycles" />
    <configuration counter="ARMv8_Cortex_A55_metric_dtlb_walk_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_dtlb_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_crypto_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_cpi" />
    <configuration counter="ARMv8_Cortex_A55_metric_branch_return_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_branch_percentage" />
    <configuration counter="ARMv8_Cortex_A55_metric_branch_mpki" />
    <configuration counter="ARMv8_Cortex_A55_metric_branch_misprediction_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_branch_direct_ratio" />
    <configuration counter="ARMv8_Cortex_A55_metric_backend_stalled_cycles" />
    <configuration counter="ARMv8_Cortex_A55_metric_backend_stall_interlock_bound" />
    <configuration counter="ARMv8_Cortex_A55_cnt5" />
    <configuration counter="ARMv8_Cortex_A55_cnt4" />
    <configuration counter="ARMv8_Cortex_A55_cnt3" />
    <configuration counter="ARMv8_Cortex_A55_cnt2" />
    <configuration counter="ARMv8_Cortex_A55_cnt1" />
    <configuration counter="ARMv8_Cortex_A55_cnt0" />
    <configuration counter="ARMv8_Cortex_A55_ccnt" />
    <configuration counter="ARMv8_Cortex_A78_metric_strex_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_strex_fail_percent" />
    <configuration counter="ARMv8_Cortex_A78_metric_strex_fail_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_store_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_simd_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_scalar_fp_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_retiring" />
    <configuration counter="ARMv8_Cortex_A78_metric_retired_ops_percent" />
    <configuration counter="ARMv8_Cortex_A78_metric_rc_st_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_rc_ld_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_load_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_ll_cache_read_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_ll_cache_read_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_ll_cache_read_hit_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_ldrex_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_l3_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_l3_cache_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_l2d_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_l2d_cache_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_l2_tlb_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_l2_tlb_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_l2_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_l2_cache_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_l1i_tlb_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_l1i_tlb_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_l1i_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_l1i_cache_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_l1d_tlb_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_l1d_tlb_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_l1d_cache_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_l1d_cache_miss_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_itlb_walk_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_itlb_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_ipc" />
    <configuration counter="ARMv8_Cortex_A78_metric_integer_dp_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_frontend_stalled_cycles" />
    <configuration counter="ARMv8_Cortex_A78_metric_dtlb_walk_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_dtlb_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_crypto_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_cpi" />
    <configuration counter="ARMv8_Cortex_A78_metric_branch_percentage" />
    <configuration counter="ARMv8_Cortex_A78_metric_branch_mpki" />
    <configuration counter="ARMv8_Cortex_A78_metric_branch_misprediction_ratio" />
    <configuration counter="ARMv8_Cortex_A78_metric_backend_stalled_cycles" />
    <configuration counter="ARMv8_Cortex_A78_metric_backend_mem_bound" />
    <configuration counter="ARMv8_Cortex_A78_metric_backend_bound" />
    <configuration counter="ARMv8_Cortex_A78_cnt5" />
    <configuration counter="ARMv8_Cortex_A78_cnt4" />
    <configuration counter="ARMv8_Cortex_A78_cnt3" />
    <configuration counter="ARMv8_Cortex_A78_cnt2" />
    <configuration counter="ARMv8_Cortex_A78_cnt1" />
    <configuration counter="ARMv8_Cortex_A78_cnt0" />
    <configuration counter="ARMv8_Cortex_A78_ccnt" />
    <configuration counter="diskstats_dm-10_writes" />
    <configuration counter="diskstats_dm-10_reads" />
    <configuration counter="diskstats_dm-9_writes" />
    <configuration counter="diskstats_dm-9_reads" />
    <configuration counter="diskstats_dm-8_writes" />
    <configuration counter="diskstats_dm-8_reads" />
    <configuration counter="diskstats_dm-7_writes" />
    <configuration counter="diskstats_dm-7_reads" />
    <configuration counter="diskstats_dm-6_writes" />
    <configuration counter="diskstats_dm-6_reads" />
    <configuration counter="diskstats_dm-5_writes" />
    <configuration counter="diskstats_dm-5_reads" />
    <configuration counter="diskstats_dm-4_writes" />
    <configuration counter="diskstats_dm-4_reads" />
    <configuration counter="diskstats_dm-3_writes" />
    <configuration counter="diskstats_dm-3_reads" />
    <configuration counter="diskstats_dm-2_writes" />
    <configuration counter="diskstats_dm-2_reads" />
    <configuration counter="diskstats_dm-1_writes" />
    <configuration counter="diskstats_dm-1_reads" />
    <configuration counter="diskstats_dm-0_writes" />
    <configuration counter="diskstats_dm-0_reads" />
    <configuration counter="diskstats_mmcblk0boot1_writes" />
    <configuration counter="diskstats_mmcblk0boot1_reads" />
    <configuration counter="diskstats_mmcblk0boot0_writes" />
    <configuration counter="diskstats_mmcblk0boot0_reads" />
    <configuration counter="diskstats_mmcblk0p67_writes" />
    <configuration counter="diskstats_mmcblk0p67_reads" />
    <configuration counter="diskstats_mmcblk0p66_writes" />
    <configuration counter="diskstats_mmcblk0p66_reads" />
    <configuration counter="diskstats_mmcblk0p65_writes" />
    <configuration counter="diskstats_mmcblk0p65_reads" />
    <configuration counter="diskstats_mmcblk0p64_writes" />
    <configuration counter="diskstats_mmcblk0p64_reads" />
    <configuration counter="diskstats_mmcblk0p63_writes" />
    <configuration counter="diskstats_mmcblk0p63_reads" />
    <configuration counter="diskstats_mmcblk0p62_writes" />
    <configuration counter="diskstats_mmcblk0p62_reads" />
    <configuration counter="diskstats_mmcblk0p61_writes" />
    <configuration counter="diskstats_mmcblk0p61_reads" />
    <configuration counter="diskstats_mmcblk0p60_writes" />
    <configuration counter="diskstats_mmcblk0p60_reads" />
    <configuration counter="diskstats_mmcblk0p59_writes" />
    <configuration counter="diskstats_mmcblk0p59_reads" />
    <configuration counter="diskstats_mmcblk0p58_writes" />
    <configuration counter="diskstats_mmcblk0p58_reads" />
    <configuration counter="diskstats_mmcblk0p57_writes" />
    <configuration counter="diskstats_mmcblk0p57_reads" />
    <configuration counter="diskstats_mmcblk0p56_writes" />
    <configuration counter="diskstats_mmcblk0p56_reads" />
    <configuration counter="diskstats_mmcblk0p55_writes" />
    <configuration counter="diskstats_mmcblk0p55_reads" />
    <configuration counter="diskstats_mmcblk0p54_writes" />
    <configuration counter="diskstats_mmcblk0p54_reads" />
    <configuration counter="diskstats_mmcblk0p53_writes" />
    <configuration counter="diskstats_mmcblk0p53_reads" />
    <configuration counter="diskstats_mmcblk0p52_writes" />
    <configuration counter="diskstats_mmcblk0p52_reads" />
    <configuration counter="diskstats_mmcblk0p51_writes" />
    <configuration counter="diskstats_mmcblk0p51_reads" />
    <configuration counter="diskstats_mmcblk0p50_writes" />
    <configuration counter="diskstats_mmcblk0p50_reads" />
    <configuration counter="diskstats_mmcblk0p49_writes" />
    <configuration counter="diskstats_mmcblk0p49_reads" />
    <configuration counter="diskstats_mmcblk0p48_writes" />
    <configuration counter="diskstats_mmcblk0p48_reads" />
    <configuration counter="diskstats_mmcblk0p47_writes" />
    <configuration counter="diskstats_mmcblk0p47_reads" />
    <configuration counter="diskstats_mmcblk0p46_writes" />
    <configuration counter="diskstats_mmcblk0p46_reads" />
    <configuration counter="diskstats_mmcblk0p45_writes" />
    <configuration counter="diskstats_mmcblk0p45_reads" />
    <configuration counter="diskstats_mmcblk0p44_writes" />
    <configuration counter="diskstats_mmcblk0p44_reads" />
    <configuration counter="diskstats_mmcblk0p43_writes" />
    <configuration counter="diskstats_mmcblk0p43_reads" />
    <configuration counter="diskstats_mmcblk0p42_writes" />
    <configuration counter="diskstats_mmcblk0p42_reads" />
    <configuration counter="diskstats_mmcblk0p41_writes" />
    <configuration counter="diskstats_mmcblk0p41_reads" />
    <configuration counter="diskstats_mmcblk0p40_writes" />
    <configuration counter="diskstats_mmcblk0p40_reads" />
    <configuration counter="diskstats_mmcblk0p39_writes" />
    <configuration counter="diskstats_mmcblk0p39_reads" />
    <configuration counter="diskstats_mmcblk0p38_writes" />
    <configuration counter="diskstats_mmcblk0p38_reads" />
    <configuration counter="diskstats_mmcblk0p37_writes" />
    <configuration counter="diskstats_mmcblk0p37_reads" />
    <configuration counter="diskstats_mmcblk0p36_writes" />
    <configuration counter="diskstats_mmcblk0p36_reads" />
    <configuration counter="diskstats_mmcblk0p35_writes" />
    <configuration counter="diskstats_mmcblk0p35_reads" />
    <configuration counter="diskstats_mmcblk0p34_writes" />
    <configuration counter="diskstats_mmcblk0p34_reads" />
    <configuration counter="diskstats_mmcblk0p33_writes" />
    <configuration counter="diskstats_mmcblk0p33_reads" />
    <configuration counter="diskstats_mmcblk0p32_writes" />
    <configuration counter="diskstats_mmcblk0p32_reads" />
    <configuration counter="diskstats_mmcblk0p31_writes" />
    <configuration counter="diskstats_mmcblk0p31_reads" />
    <configuration counter="diskstats_mmcblk0p30_writes" />
    <configuration counter="diskstats_mmcblk0p30_reads" />
    <configuration counter="diskstats_mmcblk0p29_writes" />
    <configuration counter="diskstats_mmcblk0p29_reads" />
    <configuration counter="diskstats_mmcblk0p28_writes" />
    <configuration counter="diskstats_mmcblk0p28_reads" />
    <configuration counter="diskstats_mmcblk0p27_writes" />
    <configuration counter="diskstats_mmcblk0p27_reads" />
    <configuration counter="diskstats_mmcblk0p26_writes" />
    <configuration counter="diskstats_mmcblk0p26_reads" />
    <configuration counter="diskstats_mmcblk0p25_writes" />
    <configuration counter="diskstats_mmcblk0p25_reads" />
    <configuration counter="diskstats_mmcblk0p24_writes" />
    <configuration counter="diskstats_mmcblk0p24_reads" />
    <configuration counter="diskstats_mmcblk0p23_writes" />
    <configuration counter="diskstats_mmcblk0p23_reads" />
    <configuration counter="diskstats_mmcblk0p22_writes" />
    <configuration counter="diskstats_mmcblk0p22_reads" />
    <configuration counter="diskstats_mmcblk0p21_writes" />
    <configuration counter="diskstats_mmcblk0p21_reads" />
    <configuration counter="diskstats_mmcblk0p20_writes" />
    <configuration counter="diskstats_mmcblk0p20_reads" />
    <configuration counter="diskstats_mmcblk0p19_writes" />
    <configuration counter="diskstats_mmcblk0p19_reads" />
    <configuration counter="diskstats_mmcblk0p18_writes" />
    <configuration counter="diskstats_mmcblk0p18_reads" />
    <configuration counter="diskstats_mmcblk0p17_writes" />
    <configuration counter="diskstats_mmcblk0p17_reads" />
    <configuration counter="diskstats_mmcblk0p16_writes" />
    <configuration counter="diskstats_mmcblk0p16_reads" />
    <configuration counter="diskstats_mmcblk0p15_writes" />
    <configuration counter="diskstats_mmcblk0p15_reads" />
    <configuration counter="diskstats_mmcblk0p14_writes" />
    <configuration counter="diskstats_mmcblk0p14_reads" />
    <configuration counter="diskstats_mmcblk0p13_writes" />
    <configuration counter="diskstats_mmcblk0p13_reads" />
    <configuration counter="diskstats_mmcblk0p12_writes" />
    <configuration counter="diskstats_mmcblk0p12_reads" />
    <configuration counter="diskstats_mmcblk0p11_writes" />
    <configuration counter="diskstats_mmcblk0p11_reads" />
    <configuration counter="diskstats_mmcblk0p10_writes" />
    <configuration counter="diskstats_mmcblk0p10_reads" />
    <configuration counter="diskstats_mmcblk0p9_writes" />
    <configuration counter="diskstats_mmcblk0p9_reads" />
    <configuration counter="diskstats_mmcblk0p8_writes" />
    <configuration counter="diskstats_mmcblk0p8_reads" />
    <configuration counter="diskstats_mmcblk0p7_writes" />
    <configuration counter="diskstats_mmcblk0p7_reads" />
    <configuration counter="diskstats_mmcblk0p6_writes" />
    <configuration counter="diskstats_mmcblk0p6_reads" />
    <configuration counter="diskstats_mmcblk0p5_writes" />
    <configuration counter="diskstats_mmcblk0p5_reads" />
    <configuration counter="diskstats_mmcblk0p4_writes" />
    <configuration counter="diskstats_mmcblk0p4_reads" />
    <configuration counter="diskstats_mmcblk0p3_writes" />
    <configuration counter="diskstats_mmcblk0p3_reads" />
    <configuration counter="diskstats_mmcblk0p2_writes" />
    <configuration counter="diskstats_mmcblk0p2_reads" />
    <configuration counter="diskstats_mmcblk0p1_writes" />
    <configuration counter="diskstats_mmcblk0p1_reads" />
    <configuration counter="diskstats_mmcblk0_writes" />
    <configuration counter="diskstats_mmcblk0_reads" />
    <configuration counter="diskstats_zram0_writes" />
    <configuration counter="diskstats_zram0_reads" />
    <configuration counter="diskstats_loop15_writes" />
    <configuration counter="diskstats_loop15_reads" />
    <configuration counter="diskstats_loop14_writes" />
    <configuration counter="diskstats_loop14_reads" />
    <configuration counter="diskstats_loop13_writes" />
    <configuration counter="diskstats_loop13_reads" />
    <configuration counter="diskstats_loop12_writes" />
    <configuration counter="diskstats_loop12_reads" />
    <configuration counter="diskstats_loop11_writes" />
    <configuration counter="diskstats_loop11_reads" />
    <configuration counter="diskstats_loop10_writes" />
    <configuration counter="diskstats_loop10_reads" />
    <configuration counter="diskstats_loop9_writes" />
    <configuration counter="diskstats_loop9_reads" />
    <configuration counter="diskstats_loop8_writes" />
    <configuration counter="diskstats_loop8_reads" />
    <configuration counter="diskstats_loop7_writes" />
    <configuration counter="diskstats_loop7_reads" />
    <configuration counter="diskstats_loop6_writes" />
    <configuration counter="diskstats_loop6_reads" />
    <configuration counter="diskstats_loop5_writes" />
    <configuration counter="diskstats_loop5_reads" />
    <configuration counter="diskstats_loop4_writes" />
    <configuration counter="diskstats_loop4_reads" />
    <configuration counter="diskstats_loop3_writes" />
    <configuration counter="diskstats_loop3_reads" />
    <configuration counter="diskstats_loop2_writes" />
    <configuration counter="diskstats_loop2_reads" />
    <configuration counter="diskstats_loop1_writes" />
    <configuration counter="diskstats_loop1_reads" />
    <configuration counter="diskstats_loop0_writes" />
    <configuration counter="diskstats_loop0_reads" />
    <configuration counter="diskstats_ram15_writes" />
    <configuration counter="diskstats_ram15_reads" />
    <configuration counter="diskstats_ram14_writes" />
    <configuration counter="diskstats_ram14_reads" />
    <configuration counter="diskstats_ram13_writes" />
    <configuration counter="diskstats_ram13_reads" />
    <configuration counter="diskstats_ram12_writes" />
    <configuration counter="diskstats_ram12_reads" />
    <configuration counter="diskstats_ram11_writes" />
    <configuration counter="diskstats_ram11_reads" />
    <configuration counter="diskstats_ram10_writes" />
    <configuration counter="diskstats_ram10_reads" />
    <configuration counter="diskstats_ram9_writes" />
    <configuration counter="diskstats_ram9_reads" />
    <configuration counter="diskstats_ram8_writes" />
    <configuration counter="diskstats_ram8_reads" />
    <configuration counter="diskstats_ram7_writes" />
    <configuration counter="diskstats_ram7_reads" />
    <configuration counter="diskstats_ram6_writes" />
    <configuration counter="diskstats_ram6_reads" />
    <configuration counter="diskstats_ram5_writes" />
    <configuration counter="diskstats_ram5_reads" />
    <configuration counter="diskstats_ram4_writes" />
    <configuration counter="diskstats_ram4_reads" />
    <configuration counter="diskstats_ram3_writes" />
    <configuration counter="diskstats_ram3_reads" />
    <configuration counter="diskstats_ram2_writes" />
    <configuration counter="diskstats_ram2_reads" />
    <configuration counter="diskstats_ram1_writes" />
    <configuration counter="diskstats_ram1_reads" />
    <configuration counter="diskstats_ram0_writes" />
    <configuration counter="diskstats_ram0_reads" />
    <configuration counter="Linux_block_rq_wr" />
    <configuration counter="Linux_block_rq_rd" />
    <configuration counter="Linux_meminfo_slab" />
    <configuration counter="Linux_meminfo_cached" />
    <configuration counter="Linux_meminfo_bufferram" />
    <configuration counter="Linux_meminfo_memfree" />
    <configuration counter="Linux_meminfo_memused2" />
    <configuration counter="Linux_net_tx" />
    <configuration counter="Linux_net_rx" />
    <configuration counter="Android_ThermalState" />
    <configuration counter="ARM_Mali-G57_L2_EXT_SNOOP_INTERNAL" />
    <configuration counter="ARM_Mali-G57_L2_EXT_SNOOP_RESP_DATA" />
    <configuration counter="ARM_Mali-G57_L2_EXT_SNOOP_RESP_CLEAN" />
    <configuration counter="ARM_Mali-G57_L2_EXT_SNOOP_STALL" />
    <configuration counter="ARM_Mali-G57_L2_EXT_SNOOP" />
    <configuration counter="ARM_Mali-G57_L2_EXT_AW_CNT_Q3" />
    <configuration counter="ARM_Mali-G57_L2_EXT_AW_CNT_Q2" />
    <configuration counter="ARM_Mali-G57_L2_EXT_AW_CNT_Q1" />
    <configuration counter="ARM_Mali-G57_L2_EXT_W_STALL" />
    <configuration counter="ARM_Mali-G57_L2_EXT_WRITE_BEATS" />
    <configuration counter="ARM_Mali-G57_L2_EXT_WRITE_SNP_PTL" />
    <configuration counter="ARM_Mali-G57_L2_EXT_WRITE_SNP_FULL" />
    <configuration counter="ARM_Mali-G57_L2_EXT_WRITE_NOSNP_PTL" />
    <configuration counter="ARM_Mali-G57_L2_EXT_WRITE_NOSNP_FULL" />
    <configuration counter="ARM_Mali-G57_L2_EXT_WRITE" />
    <configuration counter="ARM_Mali-G57_L2_EXT_RRESP_320_383" />
    <configuration counter="ARM_Mali-G57_L2_EXT_RRESP_256_319" />
    <configuration counter="ARM_Mali-G57_L2_EXT_RRESP_192_255" />
    <configuration counter="ARM_Mali-G57_L2_EXT_RRESP_128_191" />
    <configuration counter="ARM_Mali-G57_L2_EXT_RRESP_0_127" />
    <configuration counter="ARM_Mali-G57_L2_EXT_AR_CNT_Q3" />
    <configuration counter="ARM_Mali-G57_L2_EXT_AR_CNT_Q2" />
    <configuration counter="ARM_Mali-G57_L2_EXT_AR_CNT_Q1" />
    <configuration counter="ARM_Mali-G57_L2_EXT_AR_STALL" />
    <configuration counter="ARM_Mali-G57_L2_EXT_READ_BEATS" />
    <configuration counter="ARM_Mali-G57_L2_EXT_READ_UNIQUE" />
    <configuration counter="ARM_Mali-G57_L2_EXT_READ_NOSNP" />
    <configuration counter="ARM_Mali-G57_L2_EXT_READ" />
    <configuration counter="ARM_Mali-G57_L2_EXT_SNOOP_LOOKUP" />
    <configuration counter="ARM_Mali-G57_L2_WRITE_LOOKUP" />
    <configuration counter="ARM_Mali-G57_L2_READ_LOOKUP" />
    <configuration counter="ARM_Mali-G57_L2_ANY_LOOKUP" />
    <configuration counter="ARM_Mali-G57_L2_WR_MSG_OUT" />
    <configuration counter="ARM_Mali-G57_L2_RD_MSG_OUT_STALL" />
    <configuration counter="ARM_Mali-G57_L2_RD_MSG_OUT" />
    <configuration counter="ARM_Mali-G57_L2_SNP_MSG_IN_STALL" />
    <configuration counter="ARM_Mali-G57_L2_SNP_MSG_IN" />
    <configuration counter="ARM_Mali-G57_L2_WR_MSG_IN_STALL" />
    <configuration counter="ARM_Mali-G57_L2_WR_MSG_IN" />
    <configuration counter="ARM_Mali-G57_L2_RD_MSG_IN_STALL" />
    <configuration counter="ARM_Mali-G57_L2_RD_MSG_IN" />
    <configuration counter="ARM_Mali-G57_MMU_S2_HIT_L2" />
    <configuration counter="ARM_Mali-G57_MMU_S2_HIT_L3" />
    <configuration counter="ARM_Mali-G57_MMU_S2_TABLE_READS_L2" />
    <configuration counter="ARM_Mali-G57_MMU_S2_TABLE_READS_L3" />
    <configuration counter="ARM_Mali-G57_MMU_S2_REQUESTS" />
    <configuration counter="ARM_Mali-G57_MMU_HIT_L2" />
    <configuration counter="ARM_Mali-G57_MMU_HIT_L3" />
    <configuration counter="ARM_Mali-G57_MMU_TABLE_READS_L2" />
    <configuration counter="ARM_Mali-G57_MMU_TABLE_READS_L3" />
    <configuration counter="ARM_Mali-G57_MMU_REQUESTS" />
    <configuration counter="ARM_Mali-G57_BEATS_WR_LSC_WB" />
    <configuration counter="ARM_Mali-G57_BEATS_WR_TIB" />
    <configuration counter="ARM_Mali-G57_BEATS_WR_LSC_OTHER" />
    <configuration counter="ARM_Mali-G57_BEATS_RD_OTHER" />
    <configuration counter="ARM_Mali-G57_BEATS_RD_TEX_EXT" />
    <configuration counter="ARM_Mali-G57_BEATS_RD_TEX" />
    <configuration counter="ARM_Mali-G57_BEATS_RD_LSC_EXT" />
    <configuration counter="ARM_Mali-G57_BEATS_RD_LSC" />
    <configuration counter="ARM_Mali-G57_BEATS_RD_FTC_EXT" />
    <configuration counter="ARM_Mali-G57_BEATS_RD_FTC" />
    <configuration counter="ARM_Mali-G57_ARITH_INSTR_FP_MUL" />
    <configuration counter="ARM_Mali-G57_ATTR_INSTR" />
    <configuration counter="ARM_Mali-G57_VARY_SLOT_16" />
    <configuration counter="ARM_Mali-G57_VARY_SLOT_32" />
    <configuration counter="ARM_Mali-G57_VARY_INSTR" />
    <configuration counter="ARM_Mali-G57_LS_MEM_ATOMIC" />
    <configuration counter="ARM_Mali-G57_LS_MEM_WRITE_SHORT" />
    <configuration counter="ARM_Mali-G57_LS_MEM_WRITE_FULL" />
    <configuration counter="ARM_Mali-G57_LS_MEM_READ_SHORT" />
    <configuration counter="ARM_Mali-G57_LS_MEM_READ_FULL" />
    <configuration counter="ARM_Mali-G57_TEX_MSGO_NUM_FLITS" />
    <configuration counter="ARM_Mali-G57_TEX_MSGO_NUM_MSG" />
    <configuration counter="ARM_Mali-G57_TEX_FILT_NUM_FST_OPERATIONS" />
    <configuration counter="ARM_Mali-G57_TEX_FILT_NUM_FXR_OPERATIONS" />
    <configuration counter="ARM_Mali-G57_TEX_FILT_NUM_OPERATIONS" />
    <configuration counter="ARM_Mali-G57_TEX_TFCH_STARVED_PENDING_DATA_FETCH" />
    <configuration counter="ARM_Mali-G57_TEX_TFCH_CLK_STALLED" />
    <configuration counter="ARM_Mali-G57_TEX_DFCH_CLK_STALLED" />
    <configuration counter="ARM_Mali-G57_TEX_MSGI_NUM_FLITS" />
    <configuration counter="ARM_Mali-G57_CALL_BLEND_SHADER" />
    <configuration counter="ARM_Mali-G57_EXEC_STARVE_ARITH" />
    <configuration counter="ARM_Mali-G57_EXEC_ICACHE_MISS" />
    <configuration counter="ARM_Mali-G57_EXEC_INSTR_DIVERGED" />
    <configuration counter="ARM_Mali-G57_EXEC_INSTR_MSG" />
    <configuration counter="ARM_Mali-G57_EXEC_INSTR_SFU" />
    <configuration counter="ARM_Mali-G57_EXEC_INSTR_CVT" />
    <configuration counter="ARM_Mali-G57_EXEC_INSTR_FMA" />
    <configuration counter="ARM_Mali-G57_EXEC_CORE_ACTIVE" />
    <configuration counter="ARM_Mali-G57_COMPUTE_STARVING" />
    <configuration counter="ARM_Mali-G57_COMPUTE_WARPS" />
    <configuration counter="ARM_Mali-G57_COMPUTE_TASKS" />
    <configuration counter="ARM_Mali-G57_COMPUTE_ACTIVE" />
    <configuration counter="ARM_Mali-G57_FULL_QUAD_WARPS" />
    <configuration counter="ARM_Mali-G57_QUAD_FPK_KILLER" />
    <configuration counter="ARM_Mali-G57_FRAG_TRANS_ELIM" />
    <configuration counter="ARM_Mali-G57_FRAG_PTILES" />
    <configuration counter="ARM_Mali-G57_WARP_REG_SIZE_64" />
    <configuration counter="ARM_Mali-G57_FRAG_LZS_KILL" />
    <configuration counter="ARM_Mali-G57_FRAG_LZS_TEST" />
    <configuration counter="ARM_Mali-G57_FRAG_QUADS_EZS_KILL" />
    <configuration counter="ARM_Mali-G57_FRAG_QUADS_EZS_UPDATE" />
    <configuration counter="ARM_Mali-G57_FRAG_QUADS_EZS_TEST" />
    <configuration counter="ARM_Mali-G57_FRAG_QUADS_RAST" />
    <configuration counter="ARM_Mali-G57_FRAG_PARTIAL_QUADS_RAST" />
    <configuration counter="ARM_Mali-G57_FRAG_WARPS" />
    <configuration counter="ARM_Mali-G57_FRAG_STARVING" />
    <configuration counter="ARM_Mali-G57_FRAG_FPK_ACTIVE" />
    <configuration counter="ARM_Mali-G57_FRAG_PRIM_RAST" />
    <configuration counter="ARM_Mali-G57_FRAG_PRIMITIVES_OUT" />
    <configuration counter="ARM_Mali-G57_FRAG_ACTIVE" />
    <configuration counter="ARM_Mali-G57_UTLB1_MMU_REQ" />
    <configuration counter="ARM_Mali-G57_UTLB1_TRANS_STALL" />
    <configuration counter="ARM_Mali-G57_UTLB1_TRANS_HIT" />
    <configuration counter="ARM_Mali-G57_UTLB1_TRANS" />
    <configuration counter="ARM_Mali-G57_UTLB0_MMU_REQ" />
    <configuration counter="ARM_Mali-G57_UTLB0_TRANS_STALL" />
    <configuration counter="ARM_Mali-G57_UTLB0_TRANS_HIT" />
    <configuration counter="ARM_Mali-G57_UTLB0_TRANS" />
    <configuration counter="ARM_Mali-G57_WRBUF_ASN_STALL" />
    <configuration counter="ARM_Mali-G57_WRBUF_NO_ASN_ID_STALL" />
    <configuration counter="ARM_Mali-G57_WRBUF_NO_FREE_LINE_STALL" />
    <configuration counter="ARM_Mali-G57_WRBUF_MISS" />
    <configuration counter="ARM_Mali-G57_WRBUF_HIT" />
    <configuration counter="ARM_Mali-G57_WRBUF_ACTIVE" />
    <configuration counter="ARM_Mali-G57_PMGR_CMD_WR_STALL" />
    <configuration counter="ARM_Mali-G57_PMGR_PTR_RD_STALL" />
    <configuration counter="ARM_Mali-G57_PMGR_PTR_WR_STALL" />
    <configuration counter="ARM_Mali-G57_PCACHE_EVICT_STALL" />
    <configuration counter="ARM_Mali-G57_PCACHE_MISS_STALL" />
    <configuration counter="ARM_Mali-G57_PCACHE_MISS" />
    <configuration counter="ARM_Mali-G57_PCACHE_HIT" />
    <configuration counter="ARM_Mali-G57_COMPRESS_STALL" />
    <configuration counter="ARM_Mali-G57_COMPRESS_MISS" />
    <configuration counter="ARM_Mali-G57_ITER_STALL" />
    <configuration counter="ARM_Mali-G57_BINNER_STALL" />
    <configuration counter="ARM_Mali-G57_IDVS_VAR_SHAD_STALL" />
    <configuration counter="ARM_Mali-G57_IDVS_VAR_SHAD_REQ" />
    <configuration counter="ARM_Mali-G57_IDVS_VBU_LINE_DEALLOCATE" />
    <configuration counter="ARM_Mali-G57_IDVS_VBU_MISS" />
    <configuration counter="ARM_Mali-G57_IDVS_VBU_HIT" />
    <configuration counter="ARM_Mali-G57_BBOX_GEN_STALL" />
    <configuration counter="ARM_Mali-G57_PRIMASSY_STALL" />
    <configuration counter="ARM_Mali-G57_VFETCH_STALL" />
    <configuration counter="ARM_Mali-G57_VFETCH_VERTEX_WAIT" />
    <configuration counter="ARM_Mali-G57_VFETCH_POS_READ_WAIT" />
    <configuration counter="ARM_Mali-G57_VCACHE_LINE_WAIT" />
    <configuration counter="ARM_Mali-G57_VCACHE_MISS" />
    <configuration counter="ARM_Mali-G57_VCACHE_HIT" />
    <configuration counter="ARM_Mali-G57_PREFETCH_STALL" />
    <configuration counter="ARM_Mali-G57_IDVS_POS_FIFO_FULL" />
    <configuration counter="ARM_Mali-G57_IDVS_POS_SHAD_STALL" />
    <configuration counter="ARM_Mali-G57_IDVS_POS_SHAD_WAIT" />
    <configuration counter="ARM_Mali-G57_IDVS_POS_SHAD_REQ" />
    <configuration counter="ARM_Mali-G57_LOADING_DESC" />
    <configuration counter="ARM_Mali-G57_BUS_WRITE_UTLB1" />
    <configuration counter="ARM_Mali-G57_BUS_WRITE_UTLB0" />
    <configuration counter="ARM_Mali-G57_BUS_READ" />
    <configuration counter="ARM_Mali-G57_BIN_ALLOC_OVERFLOW" />
    <configuration counter="ARM_Mali-G57_BIN_ALLOC_INIT" />
    <configuration counter="ARM_Mali-G57_PRIM_SAT_CULLED" />
    <configuration counter="ARM_Mali-G57_PRIM_CLIPPED" />
    <configuration counter="ARM_Mali-G57_PRIM_CULLED" />
    <configuration counter="ARM_Mali-G57_PRIM_VISIBLE" />
    <configuration counter="ARM_Mali-G57_BACK_FACING" />
    <configuration counter="ARM_Mali-G57_FRONT_FACING" />
    <configuration counter="ARM_Mali-G57_POINTS" />
    <configuration counter="ARM_Mali-G57_LINES" />
    <configuration counter="ARM_Mali-G57_TRIANGLES" />
    <configuration counter="ARM_Mali-G57_JOBS_PROCESSED" />
    <configuration counter="ARM_Mali-G57_TILER_ACTIVE" />
    <configuration counter="ARM_Mali-G57_CACHE_FLUSH" />
    <configuration counter="ARM_Mali-G57_JS2_WAIT_FINISH" />
    <configuration counter="ARM_Mali-G57_JS2_WAIT_DEPEND" />
    <configuration counter="ARM_Mali-G57_JS2_WAIT_ISSUE" />
    <configuration counter="ARM_Mali-G57_JS2_WAIT_READ" />
    <configuration counter="ARM_Mali-G57_JS2_WAIT_FLUSH" />
    <configuration counter="ARM_Mali-G57_JS2_ACTIVE" />
    <configuration counter="ARM_Mali-G57_JS2_TASKS" />
    <configuration counter="ARM_Mali-G57_JS2_JOBS" />
    <configuration counter="ARM_Mali-G57_JS1_WAIT_FINISH" />
    <configuration counter="ARM_Mali-G57_JS1_WAIT_DEPEND" />
    <configuration counter="ARM_Mali-G57_JS1_WAIT_ISSUE" />
    <configuration counter="ARM_Mali-G57_JS1_WAIT_READ" />
    <configuration counter="ARM_Mali-G57_JS1_WAIT_FLUSH" />
    <configuration counter="ARM_Mali-G57_JS1_ACTIVE" />
    <configuration counter="ARM_Mali-G57_JS1_TASKS" />
    <configuration counter="ARM_Mali-G57_JS1_JOBS" />
    <configuration counter="ARM_Mali-G57_JS0_WAIT_FINISH" />
    <configuration counter="ARM_Mali-G57_JS0_WAIT_DEPEND" />
    <configuration counter="ARM_Mali-G57_JS0_WAIT_ISSUE" />
    <configuration counter="ARM_Mali-G57_JS0_WAIT_READ" />
    <configuration counter="ARM_Mali-G57_JS0_WAIT_FLUSH" />
    <configuration counter="ARM_Mali-G57_JS0_ACTIVE" />
    <configuration counter="ARM_Mali-G57_JS0_TASKS" />
    <configuration counter="ARM_Mali-G57_JS0_JOBS" />
    <configuration counter="ARM_Mali-G57_IRQ_ACTIVE" />
    <configuration counter="ARM_Mali-G57_GPU_ACTIVE" />
    <configuration counter="ARM_Mali-G57_MESSAGES_RECEIVED" />
    <configuration counter="ARM_Mali-G57_MESSAGES_SENT" />
    <configuration counter="ftrace_power_cpu_frequency" />
    <configuration counter="atrace_power" />
    <configuration counter="atrace_bionic" />
    <configuration counter="atrace_rs" />
    <configuration counter="atrace_dalvik" />
    <configuration counter="atrace_resources" />
    <configuration counter="atrace_app" />
    <configuration counter="atrace_hal" />
    <configuration counter="atrace_camera" />
    <configuration counter="atrace_video" />
    <configuration counter="atrace_audio" />
    <configuration counter="atrace_sync_manager" />
    <configuration counter="atrace_activity_manager" />
    <configuration counter="atrace_window_manager" />
    <configuration counter="atrace_webview" />
    <configuration counter="atrace_view" />
    <configuration counter="atrace_input" />
    <configuration counter="atrace_graphics" />
    <configuration counter="atrace_enable" />
    <configuration counter="MaliTimeline_Perfetto" />
</configurations>
When I import streamline-gatord-capture-svm-3d-with-configuration-xml.apc into the Streamline GUI, I do not see "Mali GPU Utilization" in the captured tabs, what could be the issue, can someone please help ?
