The ARM Mali GPU driver miscompiles a fragment shader that uses the bitwise not operation on a uvec2 variable. The shader is expected to render a black color, but the Mali GPU renders a white color instead.
uvec2
The source code of the fragment shader is as follows:
#version 300 es
precision highp float;precision highp int;
uniform int input1; // input1 = 0
layout(location = 0) out vec4 color;
void main() { uvec2 a = uvec2(input1, 2u) | 1u; // a = (1, 3) uint b = ~a.y; // b = 4294967292 float c = float(b % 2u); // c = 0.0 color = vec4(c, c, c, 1.0); // color = (0.0, 0.0, 0.0, 1.0) a.k.a. black}
void main() {
The input uniform is set to 0 during runtime. The variable `a` is set to `(uvec2(0, 2) | 1) = (1, 3)`. The variable `b` is set to `~3 = 4294967292`. The variable `c` is thus `4294967292 % 2 = 0`. The expected color is black `(0.0, 0.0, 0.0, 1.0)`, but the Mali GPU renders the color as white.
I prepared an HTML file that can be simply opened in browser to reproduce this issue. The HTML webpage contains a minimal JS script that executes the fragment shader and outputs the color to the canvas. Also, I prepared a detailed README file describing the environment and steps to reproduce the issue. You can download them all here
Thanks for the bug report - the compiler team have confirmed that we can reproduce the problem.
(MPGCOMP-22174)
Thanks for your prompt reply!
I find that this bug impacts any shader program containing a "uvec bit_op variable" pattern, and it causes incorrect results for multiple shaders that I am currently developing.
I would greatly appreciate it if you could fix such issues soon.
You're welcome! Thanks for providing more details. We'll look into the issue with shaders containing the "uvec bit_op variable" pattern right away. I understand how this could affect your development, so we'll prioritize finding a solution. I’ll keep you updated on the progress! Let me know if there’s anything else in the meantime.
