I am working on GLES program using ARM GLES3.1 Emulator ver 2.2.
glShaderSource is giving 'GL_INVALID_OPERATION' error if shader is of following form
#ifndef GL_ES
#version 400 core
#define mediump
in vec3 position;
void main() {
gl_Position = vec4(position, 1.0);
#else
attribute vec3 position;
#endif
On console it writes FATAL - GLES: <gles::GLES31Api::glShaderSource 126> Invalid version detected.
It seems it is due to line "#version 400 core", but I wonder why it should go to this line when GL_ES is defined.
Hi Sunil,
I think you shader is not "exactly" conformant to OpenGL ES Language specification.
According to Chapter 3.3. Version Declaration from The OpenGL ES Shading Language specification:
"The #version directive must be present in the first line of a shader and must be followed by a newline. It
may contain optional white-space as specified below but no other characters are allowed. The directive is
only permitted in the first line of a shader."
If you are targeting OpenGL ES, that would mean should not start a shader with #ifndef GL_ES statement if you plan to use #version directive in it.
We know that some shader language compilers have less strict rules and not really follow official specification. This is where our OpenGL ES Emulator differs a bit.
We've captured your issue and we will consider whether we should relax our shader compilation validation in the Emulator for one of next possible releases. At this point GL_INVALID_OPERATION is the correct and conformant result.
Thanks Adam. Really appreciate.
