Specifications:
- Orange pi 5 8GB
- Rockchip RK3588S
- GPU Mali G610
output of vulkaninfo
Cannot create Vulkan instance.This problem is often caused by a faulty installation of the Vulkan driver or attempting to use a GPU that does not support Vulkan.ERROR at ./vulkaninfo/vulkaninfo.h:649:vkCreateInstance failed with ERROR_INCOMPATIBLE_DRIVER
Also i notice that i'm unable to run open gl application. many indicators of driver issue. Any guide on how i can install the guide for this GPU? thanks
We do not provide binary drivers directly, except for a small number of development boards we use internally for engineering purposes. Drivers for a specific chipset or board need to be sourced from the manufacturer.
Cheers, Pete
