[Vulkan] Mali-G76 possible spirv related crash
Hi we're encountering a crash in vulkan driver which possibly related to shader code.
: pid: 20915, tid: 23289, name: TaskGraphHP 4  >>> com.demo.demo <<<
: uid: 10411
: signal 11 (SIGSEGV), code -6 (SI_TKILL), fault addr --------
:     x0  0000000000000000  x1  0000000000005af9  x2  000000000000000b  x3  0000000000000000
:     x4  4008000000000000  x5  0000000000000000  x6  0000000000000000  x7  7f7f7f7f7f7f7f7f
:     x8  0000000000000083  x9  4321f071e901995e  x10 0000007efc61205c  x11 000000000000003b
:     x12 0000000000000018  x13 ffffffffffffffff  x14 ffffffffff000000  x15 ffffffffffffffff
:     x16 0000007dfb527430  x17 0000007eff035ba0  x18 0000000000001ca4  x19 000000000000000b
:     x20 0000007da38352d0  x21 00000000000051b3  x22 00000000000028ab  x23 0000000000005af9
:     x24 0000000000000000  x25 0000000000000070  x26 0000000000000064  x27 0000007d45f5d020
:     x28 0000007dfb52c1e0  x29 0000007e04cf6d00
:     sp  0000007e04cf6a60  lr  0000007dfb42b440  pc  0000007eff035bc0
: backtrace:
:       #00 pc 000000000006cbc0  /apex/com.android.runtime/lib64/bionic/libc.so (syscall+32) (BuildId: b91c775ccc9b0556e91bc575a2511cd0)
:       #01 pc 000000000001b43c  /data/app/com.demo.demo-tRgmyU9_u7D-1Q9a9OfoMQ==/lib/arm64/libCrashSight.so (BuildId: 5fef3bf82a535d91909c996e46141b41588f1549)
:       #02 pc 0000000000004cb8  /system/bin/app_process64 (art::SignalChain::Handler(int, siginfo*, void*)+352) (BuildId: e844be217eb39b34490d3798328d1f12)
:       #03 pc 0000000000000638  [vdso] (__kernel_rt_sigreturn)
:       #04 pc 0000000000cec578  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #05 pc 0000000000ce9564  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #06 pc 0000000000ce42d8  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #07 pc 0000000000ca01c4  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #08 pc 0000000000c9e7c0  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #09 pc 0000000000c9c824  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #10 pc 00000000024864e4  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #11 pc 00000000024889c4  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #12 pc 00000000024cf1a0  /vendor/lib64/egl/libGLES_mali.so (BuildId: b4caf7da709ad611a374b5d7d59fd88f)
:       #13 pc 00000000000cf7c0  /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+36) (BuildId: b91c775ccc9b0556e91bc575a2511cd0)
:       #14 pc 00000000000721a8  /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+64) (BuildId: b91c775ccc9b0556e91bc575a2511cd0)
Device & driver info:
GpuFamily: Mali-G76
GlVersion: OpenGL ES 3.2 v1.r18p0-01rel0.e098644a2658b0905d91d87153032847
Hardware: vendor Kirin990
DeviceBuildNumber: TAS-AN00 2.0.0.280(C00E230R7P6)
VulkanVersion: 1.1.97
AndroidVersion: 10
The last PSO bound to render state is:
; SPIR-V
; Version: 1.0
; Generator: Google spiregg; 0
; Bound: 59
; Schema: 0
               OpCapability Shader
               OpMemoryModel Logical GLSL450
               OpEntryPoint Vertex %main_00000644_044c1d09 "main_00000644_044c1d09" %in_var_ATTRIBUTE0 %in_var_ATTRIBUTE1 %out_var_TEXCOORD0 %gl_Position
               OpName %type_DrawRectangleParameters "type.DrawRectangleParameters"
               OpName %DrawRectangleParameters "DrawRectangleParameters"
               OpName %in_var_ATTRIBUTE0 "in.var.ATTRIBUTE0"
               OpName %in_var_ATTRIBUTE1 "in.var.ATTRIBUTE1"
               OpName %out_var_TEXCOORD0 "out.var.TEXCOORD0"
               OpName %main_00000644_044c1d09 "main_00000644_044c1d09"
               OpDecorate %out_var_TEXCOORD0 NoPerspective
               OpDecorate %gl_Position BuiltIn Position
               OpDecorate %gl_Position Invariant
               OpDecorate %in_var_ATTRIBUTE0 Location 0
               OpDecorate %in_var_ATTRIBUTE1 Location 1
               OpDecorate %out_var_TEXCOORD0 Location 0
               OpDecorate %DrawRectangleParameters DescriptorSet 0
               OpDecorate %DrawRectangleParameters Binding 0
               OpMemberDecorate %type_DrawRectangleParameters 0 Offset 0
               OpMemberDecorate %type_DrawRectangleParameters 1 Offset 16
               OpMemberDecorate %type_DrawRectangleParameters 2 Offset 32
               OpDecorate %type_DrawRectangleParameters Block
      %float = OpTypeFloat 32
    %v4float = OpTypeVector %float 4
    %v2float = OpTypeVector %float 2
        %int = OpTypeInt 32 1
    %float_0 = OpConstant %float 0
    %float_1 = OpConstant %float 1
      %int_1 = OpConstant %int 1
      %int_0 = OpConstant %int 0
   %float_n1 = OpConstant %float -1
         %17 = OpConstantComposite %v2float %float_n1 %float_n1
    %float_2 = OpConstant %float 2
      %int_2 = OpConstant %int 2
         %20 = OpConstantComposite %v2float %float_1 %float_n1
%type_DrawRectangleParameters = OpTypeStruct %v4float %v4float %v4float
%_ptr_Uniform_type_DrawRectangleParameters = OpTypePointer Uniform %type_DrawRectangleParameters
%_ptr_Input_v2float = OpTypePointer Input %v2float
%_ptr_Output_v2float = OpTypePointer Output %v2float
%_ptr_Output_v4float = OpTypePointer Output %v4float
       %void = OpTypeVoid
         %26 = OpTypeFunction %void
%_ptr_Uniform_v4float = OpTypePointer Uniform %v4float
%DrawRectangleParameters = OpVariable %_ptr_Uniform_type_DrawRectangleParameters Uniform
%in_var_ATTRIBUTE0 = OpVariable %_ptr_Input_v2float Input
%in_var_ATTRIBUTE1 = OpVariable %_ptr_Input_v2float Input
%out_var_TEXCOORD0 = OpVariable %_ptr_Output_v2float Output
%gl_Position = OpVariable %_ptr_Output_v4float Output
         %28 = OpConstantNull %v4float
%main_00000644_044c1d09 = OpFunction %void None %26
         %29 = OpLabel
         %30 = OpLoad %v2float %in_var_ATTRIBUTE0
         %31 = OpLoad %v2float %in_var_ATTRIBUTE1
         %32 = OpCompositeExtract %float %30 0
         %33 = OpCompositeExtract %float %30 1
         %34 = OpCompositeConstruct %v4float %32 %33 %float_0 %float_1
         %35 = OpAccessChain %_ptr_Uniform_v4float %DrawRectangleParameters %int_0
         %36 = OpLoad %v4float %35
         %37 = OpVectorShuffle %v2float %36 %36 2 3
         %38 = OpVectorShuffle %v2float %34 %34 0 1
         %39 = OpVectorShuffle %v2float %36 %36 0 1
         %40 = OpFMul %v2float %38 %39
         %41 = OpFAdd %v2float %37 %40
         %42 = OpVectorTimesScalar %v2float %41 %float_2
         %43 = OpAccessChain %_ptr_Uniform_v4float %DrawRectangleParameters %int_2
         %44 = OpLoad %v4float %43
         %45 = OpVectorShuffle %v2float %44 %44 0 1
         %46 = OpFMul %v2float %42 %45
         %47 = OpFAdd %v2float %17 %46
         %48 = OpVectorShuffle %v2float %47 %28 0 1
         %49 = OpFMul %v2float %48 %20
         %50 = OpVectorShuffle %v4float %34 %49 4 5 2 3
         %51 = OpAccessChain %_ptr_Uniform_v4float %DrawRectangleParameters %int_1
         %52 = OpLoad %v4float %51
         %53 = OpVectorShuffle %v2float %52 %52 2 3
         %54 = OpVectorShuffle %v2float %52 %52 0 1
         %55 = OpFMul %v2float %31 %54
         %56 = OpFAdd %v2float %53 %55
         %57 = OpVectorShuffle %v2float %44 %44 2 3
         %58 = OpFMul %v2float %56 %57
               OpStore %out_var_TEXCOORD0 %58
               OpStore %gl_Position %50
               OpReturn
               OpFunctionEnd
; SPIR-V
; Version: 1.0
; Bound: 193
; Schema: 0
               OpCapability Shader
          %1 = OpExtInstImport "GLSL.std.450"
               OpEntryPoint Fragment %main_000011b8_b2799476 "main_000011b8_b2799476" %in_var_TEXCOORD0 %out_var_SV_Target0
               OpExecutionMode %main_000011b8_b2799476 OriginUpperLeft
               OpName %type_2d_image "type.2d.image"
               OpName %InTexture "InTexture"
               OpName %type_sampler "type.sampler"
               OpName %InTextureBilinearSampler "InTextureBilinearSampler"
               OpName %type__Globals "type.$Globals"
               OpName %_Globals "$Globals"
               OpName %in_var_TEXCOORD0 "in.var.TEXCOORD0"
               OpName %out_var_SV_Target0 "out.var.SV_Target0"
               OpName %main_000011b8_b2799476 "main_000011b8_b2799476"
               OpName %type_sampled_image "type.sampled.image"
               OpDecorate %in_var_TEXCOORD0 NoPerspective
               OpDecorate %in_var_TEXCOORD0 Location 0
               OpDecorate %out_var_SV_Target0 Location 0
               OpDecorate %InTexture DescriptorSet 1
               OpDecorate %InTexture Binding 2
               OpDecorate %InTextureBilinearSampler DescriptorSet 1
               OpDecorate %InTextureBilinearSampler Binding 1
               OpDecorate %_Globals DescriptorSet 1
               OpDecorate %_Globals Binding 0
               OpMemberDecorate %type__Globals 0 Offset 0
               OpMemberDecorate %type__Globals 1 Offset 8
               OpDecorate %type__Globals Block
               OpDecorate %in_var_TEXCOORD0 RelaxedPrecision
               OpDecorate %12 RelaxedPrecision
               OpDecorate %13 RelaxedPrecision
               OpDecorate %14 RelaxedPrecision
               OpDecorate %15 RelaxedPrecision
               OpDecorate %16 RelaxedPrecision
               OpDecorate %17 RelaxedPrecision
               OpDecorate %18 RelaxedPrecision
               OpDecorate %19 RelaxedPrecision
 %float_n0_5 = OpConstant %float -0.5
  %float_0_5 = OpConstant %float 0.5
%float_0_125 = OpConstant %float 0.125
 %float_0_25 = OpConstant %float 0.25
   %float_n2 = OpConstant %float -2
         %34 = OpConstantComposite %v2float %float_1 %float_1
         %35 = OpConstantComposite %v4float %float_0 %float_0 %float_0 %float_1
%type_2d_image = OpTypeImage %float 2D 2 0 0 1 Unknown
%_ptr_UniformConstant_type_2d_image = OpTypePointer UniformConstant %type_2d_image
%type_sampler = OpTypeSampler
%_ptr_UniformConstant_type_sampler = OpTypePointer UniformConstant %type_sampler
%type__Globals = OpTypeStruct %v2float %float
%_ptr_Uniform_type__Globals = OpTypePointer Uniform %type__Globals
       %void = OpTypeVoid
         %42 = OpTypeFunction %void
       %bool = OpTypeBool
%_ptr_Uniform_v2float = OpTypePointer Uniform %v2float
%_ptr_Uniform_float = OpTypePointer Uniform %float
%type_sampled_image = OpTypeSampledImage %type_2d_image
     %v4bool = OpTypeVector %bool 4
  %InTexture = OpVariable %_ptr_UniformConstant_type_2d_image UniformConstant
%InTextureBilinearSampler = OpVariable %_ptr_UniformConstant_type_sampler UniformConstant
   %_Globals = OpVariable %_ptr_Uniform_type__Globals Uniform
%in_var_TEXCOORD0 = OpVariable %_ptr_Input_v2float Input
%out_var_SV_Target0 = OpVariable %_ptr_Output_v4float Output
         %47 = OpConstantComposite %v2float %float_n0_5 %float_n0_5
         %48 = OpConstantComposite %v2float %float_0_5 %float_n0_5
         %49 = OpConstantComposite %v2float %float_n0_5 %float_0_5
         %50 = OpConstantComposite %v2float %float_0_5 %float_0_5
         %51 = OpConstantComposite %v2float %float_0 %float_n0_5
         %52 = OpConstantComposite %v2float %float_n0_5 %float_0
         %53 = OpConstantComposite %v2float %float_0_5 %float_0
         %54 = OpConstantComposite %v2float %float_0 %float_0_5
%float_2_23606801 = OpConstant %float 2.23606801
%float_0_400000006 = OpConstant %float 0.400000006
         %57 = OpConstantComposite %v4float %float_0_400000006 %float_0_400000006 %float_0_400000006 %float_0_400000006
         %58 = OpUndef %v2float
%main_000011b8_b2799476 = OpFunction %void None %42
         %59 = OpLabel
         %12 = OpLoad %v2float %in_var_TEXCOORD0
         %13 = OpCompositeExtract %float %12 0
         %14 = OpFOrdLessThanEqual %bool %13 %float_0_5
         %15 = OpFMul %float %13 %float_2
         %16 = OpFMul %float %float_n2 %13
         %17 = OpFAdd %float %16 %float_2
         %18 = OpSelect %float %14 %15 %17
         %60 = OpCompositeInsert %v2float %18 %58 0
         %19 = OpCompositeExtract %float %12 1
         %61 = OpCompositeInsert %v2float %19 %60 1
         %62 = OpVectorTimesScalar %v2float %61 %float_2
         %63 = OpFSub %v2float %62 %34
         %64 = OpDot %float %63 %63
         %65 = OpAccessChain %_ptr_Uniform_v2float %_Globals %int_0
         %66 = OpAccessChain %_ptr_Uniform_float %_Globals %int_0 %int_1
         %67 = OpLoad %float %66
         %68 = OpFMul %float %float_2_23606801 %67
         %69 = OpFSub %float %float_1 %68
         %70 = OpExtInst %float %1 FClamp %69 %float_0 %float_1
         %71 = OpFOrdGreaterThan %bool %64 %70
               OpSelectionMerge %72 None
               OpBranchConditional %71 %73 %74
         %73 = OpLabel
         %75 = OpFMul %float %18 %float_0_5
         %76 = OpCompositeInsert %v2float %75 %61 0
         %77 = OpLoad %type_2d_image %InTexture
         %78 = OpLoad %type_sampler %InTextureBilinearSampler
         %79 = OpSampledImage %type_sampled_image %77 %78
         %80 = OpImageSampleExplicitLod %v4float %79 %76 Lod %float_0
         %81 = OpLoad %v2float %65
         %82 = OpFMul %v2float %47 %81
         %83 = OpFAdd %v2float %76 %82
         %84 = OpSampledImage %type_sampled_image %77 %78
         %85 = OpImageSampleExplicitLod %v4float %84 %83 Lod %float_0
         %86 = OpVectorTimesScalar %v4float %85 %float_0_125
         %87 = OpFAdd %v4float %80 %86
         %88 = OpFMul %v2float %48 %81
         %89 = OpFAdd %v2float %76 %88
         %90 = OpSampledImage %type_sampled_image %77 %78
         %91 = OpImageSampleExplicitLod %v4float %90 %89 Lod %float_0
         %92 = OpVectorTimesScalar %v4float %91 %float_0_125
         %93 = OpFAdd %v4float %87 %92
         %94 = OpFMul %v2float %49 %81
         %95 = OpFAdd %v2float %76 %94
         %96 = OpSampledImage %type_sampled_image %77 %78
         %97 = OpImageSampleExplicitLod %v4float %96 %95 Lod %float_0
         %98 = OpVectorTimesScalar %v4float %97 %float_0_125
         %99 = OpFAdd %v4float %93 %98
        %100 = OpFMul %v2float %50 %81
        %101 = OpFAdd %v2float %76 %100
        %102 = OpSampledImage %type_sampled_image %77 %78
        %103 = OpImageSampleExplicitLod %v4float %102 %101 Lod %float_0
        %104 = OpVectorTimesScalar %v4float %103 %float_0_125
        %105 = OpFAdd %v4float %99 %104
        %106 = OpFMul %v2float %51 %81
        %107 = OpFAdd %v2float %76 %106
        %108 = OpSampledImage %type_sampled_image %77 %78
        %109 = OpImageSampleExplicitLod %v4float %108 %107 Lod %float_0
        %110 = OpVectorTimesScalar %v4float %109 %float_0_25
        %111 = OpFAdd %v4float %105 %110
        %112 = OpFMul %v2float %52 %81
        %113 = OpFAdd %v2float %76 %112
        %114 = OpSampledImage %type_sampled_image %77 %78
        %115 = OpImageSampleExplicitLod %v4float %114 %113 Lod %float_0
        %116 = OpVectorTimesScalar %v4float %115 %float_0_25
        %117 = OpFAdd %v4float %111 %116
        %118 = OpFMul %v2float %53 %81
        %119 = OpFAdd %v2float %76 %118
        %120 = OpSampledImage %type_sampled_image %77 %78
        %121 = OpImageSampleExplicitLod %v4float %120 %119 Lod %float_0
        %122 = OpVectorTimesScalar %v4float %121 %float_0_25
        %123 = OpFAdd %v4float %117 %122
        %124 = OpFMul %v2float %54 %81
        %125 = OpFAdd %v2float %76 %124
        %126 = OpSampledImage %type_sampled_image %77 %78
        %127 = OpImageSampleExplicitLod %v4float %126 %125 Lod %float_0
        %128 = OpVectorTimesScalar %v4float %127 %float_0_25
        %129 = OpFAdd %v4float %123 %128
               OpBranch %72
         %74 = OpLabel
        %130 = OpLoad %type_2d_image %InTexture
        %131 = OpLoad %type_sampler %InTextureBilinearSampler
        %132 = OpSampledImage %type_sampled_image %130 %131
        %133 = OpImageSampleExplicitLod %v4float %132 %12 Lod %float_0
        %134 = OpLoad %v2float %65
        %135 = OpFMul %v2float %47 %134
        %136 = OpFAdd %v2float %12 %135
        %137 = OpSampledImage %type_sampled_image %130 %131
        %138 = OpImageSampleExplicitLod %v4float %137 %136 Lod %float_0
        %139 = OpVectorTimesScalar %v4float %138 %float_0_125
        %140 = OpFAdd %v4float %133 %139
        %141 = OpFMul %v2float %48 %134
        %142 = OpFAdd %v2float %12 %141
        %143 = OpSampledImage %type_sampled_image %130 %131
        %144 = OpImageSampleExplicitLod %v4float %143 %142 Lod %float_0
        %145 = OpVectorTimesScalar %v4float %144 %float_0_125
        %146 = OpFAdd %v4float %140 %145
        %147 = OpFMul %v2float %49 %134
        %148 = OpFAdd %v2float %12 %147
        %149 = OpSampledImage %type_sampled_image %130 %131
        %150 = OpImageSampleExplicitLod %v4float %149 %148 Lod %float_0
        %151 = OpVectorTimesScalar %v4float %150 %float_0_125
        %152 = OpFAdd %v4float %146 %151
        %153 = OpFMul %v2float %50 %134
        %154 = OpFAdd %v2float %12 %153
        %155 = OpSampledImage %type_sampled_image %130 %131
        %156 = OpImageSampleExplicitLod %v4float %155 %154 Lod %float_0
        %157 = OpVectorTimesScalar %v4float %156 %float_0_125
        %158 = OpFAdd %v4float %152 %157
        %159 = OpFMul %v2float %51 %134
        %160 = OpFAdd %v2float %12 %159
        %161 = OpSampledImage %type_sampled_image %130 %131
        %162 = OpImageSampleExplicitLod %v4float %161 %160 Lod %float_0
        %163 = OpVectorTimesScalar %v4float %162 %float_0_25
        %164 = OpFAdd %v4float %158 %163
        %165 = OpFMul %v2float %52 %134
        %166 = OpFAdd %v2float %12 %165
        %167 = OpSampledImage %type_sampled_image %130 %131
        %168 = OpImageSampleExplicitLod %v4float %167 %166 Lod %float_0
        %169 = OpVectorTimesScalar %v4float %168 %float_0_25
        %170 = OpFAdd %v4float %164 %169
        %171 = OpFMul %v2float %53 %134
        %172 = OpFAdd %v2float %12 %171
        %173 = OpSampledImage %type_sampled_image %130 %131
        %174 = OpImageSampleExplicitLod %v4float %173 %172 Lod %float_0
        %175 = OpVectorTimesScalar %v4float %174 %float_0_25
        %176 = OpFAdd %v4float %170 %175
        %177 = OpFMul %v2float %54 %134
        %178 = OpFAdd %v2float %12 %177
        %179 = OpSampledImage %type_sampled_image %130 %131
        %180 = OpImageSampleExplicitLod %v4float %179 %178 Lod %float_0
        %181 = OpVectorTimesScalar %v4float %180 %float_0_25
        %182 = OpFAdd %v4float %176 %181
               OpBranch %72
         %72 = OpLabel
        %183 = OpPhi %v4float %129 %73 %182 %74
        %184 = OpFMul %v4float %183 %57
        %185 = OpAccessChain %_ptr_Uniform_float %_Globals %int_1
        %186 = OpLoad %float %185
        %187 = OpCompositeConstruct %v4float %186 %186 %186 %float_1
        %188 = OpExtInst %v4float %1 FMin %187 %184
        %189 = OpIsNan %v4bool %188
        %190 = OpAny %bool %189
        %191 = OpCompositeConstruct %v4bool %190 %190 %190 %190
        %192 = OpSelect %v4float %191 %35 %188
               OpStore %out_var_SV_Target0 %192
               OpReturn
               OpFunctionEnd
The only suspicious part is that this vertex pixel shader pair's interface variable type is missmatching(float vs half).
We'll fix this issue and re-check again. But the same PSO works on other mali devices. The G76 is by far the only device that crashes.
