Hi dear Arm Community,
I have been trying to profile my game project with using Am Mobile Studio. Main reason I wanted to do that is Performance Advisor feature of this software. I could not figure it out why I am facing with errors on creating performance advisor html. files so wanted to share with you. Here is the process that I followed;
- I followed the proper settings for Unity settings and build an proper APK for my Samsung Galaxy A50(Which is listed as a compatible device).
-And then followed the instructions of performance advisor documentation. Device and Mali-GPU found. I select my target apk and then open Streamline.
/resized-image/__size/1265x713/__key/communityserver-discussions-components-files/13/FirstInitialization.png
-On Streamline I select my configure as Mali-G72 for my target application and than saved it. and then capture the performance for one minute. I am also sharing the screenshot of warnings on configure panel.
/resized-image/__size/982x752/__key/communityserver-discussions-components-files/13/Configure.png
-After finalized capture further steps followed and there was two errors that I could figured it out how to solve.
-I also tried to add requested features on configuration panel, prepared it manually etc. Tried various scenarios but the result was always the same.
I would be so happy if you have any idea what might be the main issue about this process, device or software itself.
Thank you very much for your time. Well-coded days
We have a known issue with Mobile Studio 2022.0 - the counter names in Streamline and Performance Advisor have desynchronized. This will be fixed in the release at the end of May.
Workaround is to use Mobile Studio 2021.4 - which you can download from here: https://silver.arm.com/browse/DSHVE. Note that captures must be a matched pair - capture in Streamline and analyze in Performance Advisor from the same version of Mobile Studio.
Sorry for the problems,
Kind regards, Pete
