Hello,I am trying to profile a Unity game on Android. Have followed the Unity specific steps for dev and built the apk.Then I try to run the lwi script with these params -python3 lwi_me.py --lwi-mode=capture --lwi-fps-threshold=20 -v --daemon ../../../streamline/bin/arm64/gatord --lwi-out-dir= /mnt/data/Documents/armmobilestudio/framesI see my debug app and then Select it.I then go onto starting Streamline for capture. In the meanwhile I check with adb shell "ps -A | grep gator" and it shows the package location where gatord has started -# ps -A | grep gator u0_a34 11672 3102 23184 5784 SyS_epoll_wait 754df30660 S gatord# ps -o COMMAND | grep gator/data/data/com.company.name/gatordWhen Streamline starts I choose midguard (config) as have a T860 on the SoC. It asks me that gatord is running on the system so what do you want to do... I click on advanced and choose the device visible on the screen.Start CaptureNo Data :(In the meanwhile on the device I see another gatord running -adb shell "ps -A | grep gator"u0_a34 26172 3102 25232 5816 SyS_epoll_wait 7cb9572660 S gatordu0_a34 26374 26172 25168 4348 0 7cb9573188 R gatordStreamline is unable to capture any data, the app does not automatically start and no dump comes out. Following the procedure from here - https://youtu.be/9_mdAzAx39wWhen I press enter on the lwi command window I get this -Trying to pull LWI local capture from device if there is oneTraceback (most recent call last): File "lwi_me.py", line 160, in pull_capture adb_stdout = device.adb("shell", "run-as", package, "ls", "meerkat") File "/mnt/data/Documents/arm/Arm_Mobile_Studio_2021.2/performance_advisor/lwi/helpers/gator_me.py", line 244, in adb rep = sp.run(commands, check=True, shell=shell, stdout=sp.PIPE, File "/usr/lib/python3.8/subprocess.py", line 516, in run raise CalledProcessError(retcode, process.args,subprocess.CalledProcessError: Command '['adb', '-s', 'ADBNAME', 'shell', 'run-as', 'com.company.name', 'ls', 'meerkat']' returned non-zero exit status 1.During handling of the above exception, another exception occurred:Traceback (most recent call last): File "lwi_me.py", line 655, in <module> sys.exit(main()) File "lwi_me.py", line 633, in main if not pull_capture(device, lwiOutDir, package): File "lwi_me.py", line 161, in pull_capture except CalledProcessError:NameError: name 'CalledProcessError' is not definedI am using this as a reference - developer.arm.com/.../Run-the-script-and-capture-a-Streamline-profilePS - I can run Streamline standalone and capture data from the device but I wanted to run PA on the captured data
We have a known-issue with using the LWI script with an interactive Streamline session. This will be getting fixed in the Mobile Studio 2021.3 release at the end of August.
The workaround is to:
* Run the lwi_me.py script as normal. * Try to connect with Streamline.* When you get the dialog prompting because a gator instance is already running, then choose "Reset".* Use the Streamline counter configuration option and select the GPU template. * Capture with Streamline as normal. * After the capture is finished, switch back to lwi_me.py and hit enter. * You'll get an error message from the lwi_me.py script at this point, but this can be ignored.
Let me know if that solves your problem. Kind regards, Pete
Hey Peter,
Appreciate you reaching out to me with a solution. The reset trick worked and am able to capture SL data. But LWI was giving an exception -
*********************************************************************************** exception starts
Trying to pull LWI local capture from device if there is onepackage -Traceback (most recent call last): File "lwi_me.py", line 163, in pull_capture adb_stdout = device.adb("shell", "run-as", package, "ls", "meerkat") File "/mnt/yash/data/Documents/arm/Arm_Mobile_Studio_2021.2/performance_advisor/lwi/helpers/gator_me.py", line 244, in adb rep = sp.run(commands, check=True, shell=shell, stdout=sp.PIPE, File "/usr/lib/python3.8/subprocess.py", line 516, in run raise CalledProcessError(retcode, process.args,subprocess.CalledProcessError: Command '['adb', '-s', 'devname', 'shell', 'run-as', 'com.agingtest.yash', 'ls', 'meerkat']' returned non-zero exit status 1.During handling of the above exception, another exception occurred:Traceback (most recent call last): File "lwi_me.py", line 664, in <module> sys.exit(main()) File "lwi_me.py", line 642, in main if not pull_capture(device, lwiOutDir, package): File "lwi_me.py", line 165, in pull_capture except CalledProcessError:NameError: name 'CalledProcessError' is not defined
*********************************************************************************** exception ends
So I dug through the python script. Copied the libs into the app folder on the device and created a meerkat directory as well. But unfortunately the piping is still not understood by me as the frame dump was supposed to come in meerkat and then once the capture is done it needs to be pushed to the host but the meerkat directory is always empty. But the exception is gone.
My end goal was to give the data captured by the lwi and SL to PA for analysis. But PA is complaining that - ERROR: Cannot find any frames. Please refer to the user guide for methods of providing frame data to Performance Advisor.
Apologies as the site was under maintenance and hence could not answer yesterday.
I also have an issue of running GA over a very heavy game (to be debugged) but the game does not go beyond the splash screen. Tried some tricks like changing the jvm in the ini file. But will give details of that in another bug coming your way :)
Regards
Yash
