We used mali-400 mp r3p2 driver. When captureScreen under android 4.4, eglClientWaitSyncKHR() always report timeout.
Actually we capture android screen successfully, and the image can be opened, and exactly what android showing.
We enable all debug printing, and find the log report some strange thing about ""Adding a callback to an unmodified frame! \n"" in m200_gp_frame_builder_inlines.h @_mali_frame_add_callback().
How can we fix this bug?
Code and the log information as following:
1) code of SurfaceFlinger.cpp
status_t SurfaceFlinger::captureScreenImplLocked(...)
EGLSyncKHR sync = eglCreateSyncKHR(mEGLDisplay, EGL_SYNC_FENCE_KHR, NULL);
ALOGD( "captureScreen: guan, eglCreateSyncKHR(), sync=0x%x\n", (unsigned int)sync);
if (sync != EGL_NO_SYNC_KHR) {
EGLint result = eglClientWaitSyncKHR(mEGLDisplay, sync,
EGL_SYNC_FLUSH_COMMANDS_BIT_KHR, 500000000 /*2 sec*/);
EGLint eglErr = eglGetError();
eglDestroySyncKHR(mEGLDisplay, sync);
ALOGD( "captureScreen: eglClientWaitSyncKHR(), guan, result=0x%x, eglGetError(), eglErr=0x%x\n",
result, eglErr);
if (result == EGL_TIMEOUT_EXPIRED_KHR) {
ALOGW("captureScreen: fence wait timed out");
} else {
ALOGW_IF(eglErr != EGL_SUCCESS,
"captureScreen: error waiting on EGL fence: %#x", eglErr);
ALOGW("captureScreen: error creating EGL fence: %#x", eglGetError());
// not fatal
2) debug information of mali driver.
We add comment with //. And some information with red color. We also add some print for import var.
D/SurfaceFlinger( 937): captureScreen: w=1280, h=720, layer=[0x0-0xffffffff]
D/gralloc ( 937): alloc_device_alloc(), guan, handle=0x42f19f50, hnd->pid=937, cur_pid=937, ump_id=0x1, base=0x43a27000
[ 73.680000] UMP<2>: New session opened
D/gralloc ( 1859): gralloc_register_buffer(), guan, handle=0x400eaa90, hnd->pid=1859, cur_pid=1859, ump_id=0x1, base=0x41a90000
D/gralloc ( 937): alloc_device_free(), guan, handle=0x42f19f50, hnd->pid=937, cur_pid=937, ump_id=0x1, ref=1, base=0x43a27000
D/gralloc ( 937): gralloc_register_buffer(), guan, handle=0x437da958, hnd->pid=937, cur_pid=937, ump_id=0x1, base=0x43a27000
I/ ( 937): For size 3932160 we need order 22 (4194304)
I/ ( 937): Checking freelist 0x40145E28 for order 22
I/ ( 937): Found an entry on the freelist for order 22
I/ ( 937): Lock released
I/ ( 937): Trying to map memory
I/ ( 937): Writing to Mali memory @ 0x41778C00, endian safe routine
I/ ( 937): ----- write 20 bytes @ 0x400bec00, endian safe routine
I/ ( 937): Writing to Mali memory @ 0x41778BC0, endian safe routine
I/ ( 937): ----- write 64 bytes @ 0x400bebc0, endian safe routine
I/ ( 937): F[0]
I/ ( 937): _gles_fbo_attachment_resolve_completeness_dirty: frame builder 0x42f19450: setting output 0 to NULL
I/ ( 937): _gles_fbo_attachment_resolve_completeness_dirty: frame builder 0x42f19450: setting output 0 of to 0x42f19a70
I/ ( 937): _gles_fbo_attachment_resolve_completeness_dirty: frame builder 0x42f19450: setting output 1 to NULL
I/ ( 937): _gles_fbo_attachment_resolve_completeness_dirty: frame builder 0x42f19450: setting output 2 to NULL
I/ ( 937): For size 262144 we need order 18 (262144)
I/ ( 937): Checking freelist 0x40145E08 for order 18
I/ ( 937): Checking freelist 0x40145E10 for order 19
I/ ( 937): Checking freelist 0x40145E18 for order 20
I/ ( 937): Found an entry on the freelist for order 20
I/ ( 937): Splitting slot 0x41720038
I/ ( 937): No guard pages possible
I/ ( 937): Writing to Mali memory @ 0x43A26880, endian safe routine
I/ ( 937): ----- write 20 bytes @ 0x400ff880, endian safe routine
I/ ( 937): _mali_frame_builder_add_callback(), frame->state=2
I/ ( 937): _mali_frame_add_callback(), frame->state=2
I/ ( 937): +++++ _gles_fb_commit_rsw: allocated 64 bytes @ 0x40130200
I/ ( 937): Writing to Mali memory @ 0x41778C40, endian safe routine
I/ ( 937): ----- write 16 bytes @ 0x400bec40, endian safe routine
I/ ( 937): Writing to Mali memory @ 0x43A26900, endian safe routine
I/ ( 937): ----- write 36 bytes @ 0x400ff900, endian safe routine
I/ ( 937): Writing to Mali memory @ 0x41778F80, endian safe routine
I/ ( 937): ----- write 64 bytes @ 0x400bef80, endian safe routine
I/ ( 937): Writing to Mali memory @ 0x41778FC0, endian safe routine
I/ ( 937): ----- write 64 bytes @ 0x400befc0, endian safe routine
I/ ( 937): Writing to Mali memory @ 0x41779000, endian safe routine
I/ ( 937): ----- write 64 bytes @ 0x400bf000, endian safe routine
I/ ( 937): +++++ _gles_gb_allocate_and_fill_temp_memory: allocated 64 bytes @ 0x40130540
I/ ( 93[ 74.130000] binder: release 937:1115 transaction 8373 in, still active
[ 74.130000] UMP<2>: Session closed
[ 74.130000] Mali<2>: Session ending
[ 74.130000] Mali<2>: Core: session_close: for Mali-400 GP
[ 74.130000] Mali<2>: Core: session_close: for Mali-400 PP
[ 74.130000] Mali<2>: MMU session end
[ 74.130000] Mali<1>: Cleanup of descriptor 1 mapping to 0xeaf84f20 in descriptor table
[ 74.130000] Mali<1>: Cleanup of descriptor 2 mapping to 0xe0e5a860 in descriptor table
[ 74.130000] Mali<1>: Cleanup of descriptor 3 mapping to 0xeafb9d20 in descriptor table
[ 74.130000] Mali<1>: Cleanup of descriptor 7 mapping to 0xe1b04d20 in descriptor table
[ 74.130000] Mali<1>: Cleanup of descriptor 8 mapping to 0xe1b04ea0 in descriptor table
[ 74.130000] Mali<1>: Cleanup of descriptor 9 mapping to 0xe1b04b20 in descriptor table
[ 74.132000] binder: send failed reply for transaction 8373 to 1859:1859
[ 74.133000] OSDFB(info): OSDFB: [FB0] opened. in_use = 6
I/ ( 937): _mali_frame_add_callback[ 74.155000] Mali<1>: (), frame->state=2
I/ ( 937): Writing to Mali memory @ 0x41778C80, endian safe routine
I/ ( 937): ----- write 64 bytes @ 0x400bec80, endian safe routine
I/ ( 937): Writing to Mali memory @ 0x41778CC0, endian safe routine
I/ ( 937): ----- write 64 bytes @ 0x400becc0, endian safe routine
I/ ( 937): Writing to Mali memory @ 0x41778D00, endian safe routine
I/ ( 937): ----- write 64 bytes @ 0x400bed00, endian safe routine
I/ ( 937): +++++ _gles_gb_allocate_and_fill_temp_memory: allocated 64 bytes @ 0x40130880
I/ ( 937): Found an entry on the freelist for order 18
I/ ( 937): GPS[1]
I/ ( 937): Mali gp job returned, OK!
I/ ( 937): GPE[1]
I/ ( 937): PPS[1]
I/ ( 937): Calling _mali_uku_wait_for_notification()
I/ ( 937): Mali pp job returned, OK!
I/ ( 937): Starting PP post processing
I/ ( 937): Internal frame 1121837128, job render_time: 31031 usec
I/ ( 937): PPE[1]
I/ ( 937): Freeing job
// mali driver change frame state from 2(FRAME_DIRTY) to 1(FRAME_UNMODIFIED),
// but _mali_frame_add_callback(), check as following:
//MALI_DEBUG_ASSERT( frame->state != FRAME_UNMODIFIED , ("Adding a callback to an unmodified frame! \n"));
I/ ( 937): _mali_frame_builder_add_callback(), frame->state=1
I/ ( 937): _mali_frame_add_callback(), frame->state=1
I/ ( 937): *********************************************************************
I/ ( 937): ASSERT EXIT:
I/ ( 937): In file: hardware/zte/zx296702/mali/src/shared/m200_gp_frame_builder_inlines.h function: _mali_frame_add_callback() line: 39
I/ ( 937): Adding a callback to an unmodified frame!
I/ ( 937):
F/libc ( 937): Fatal signal 11 (SIGSEGV) at 0x00000000 (code=1), thread 937 (surfaceflinger)
I/DEBUG ( 936): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 936): Build fingerprint: 'unknown'
I/DEBUG ( 936): Revision: '32'
I/DEBUG ( 936): pid: 937, tid: 937, name: surfaceflinger >>> /system/bin/surfaceflinger <<<
I/DEBUG ( 936): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 00000000
W/NativeCrashListener( 1289): Couldn't find ProcessRecord for pid 937
I/DEBUG ( 936): r0 be864830 r1 00000000 r2 00000000 r3 00000000
I/DEBUG ( 936): AM write failure (32 / Broken pipe)
I/DEBUG ( 936): r4 43103250 r5 40005df8 r6 00000001 r7 400e7690
I/DEBUG ( 936): r8 00000000 r9 10000001 sl be86487c fp be864830
I/DEBUG ( 936): ip 40480e04 sp be8647b0 lr 404773f8 pc 412439d0 cpsr 600f0010
I/DEBUG ( 936): d0 6e696c2020202928 d1 5f6464615f656d61
I/DEBUG ( 936): d2 0000000000000000 d3 0000000000000000
I/DEBUG ( 936): d4 00000000bf800000 d5 3f8000003f800000
I/DEBUG ( 936): d6 43b4000043b40000 d7 0000050043b40000
I/DEBUG ( 936): d8 0000000000000000 d9 0000000000000000
I/DEBUG ( 936): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 936): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 936): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 936): d16 280001cb400bf140 d17 0400bf140400bf14
I/DEBUG ( 936): d18 280001cb00000000 d19 000002cf000002cf
I/DEBUG ( 936): d20 00000000000002cf d21 0000000001678000
I/DEBUG ( 936): d22 0000000000000000 d23 0000000000000000
I/DEBUG ( 936): d24 7000000000000000 d25 7000000001678000
I/DEBUG ( 936): d26 0000000000000000 d27 7000000001678000
I/DEBUG ( 936): d28 009fe00000000000 d29 709fe00001678000
I/DEBUG ( 936): d30 0000000000000000 d31 4000000000000000
I/DEBUG ( 936): scr 60000010
I/DEBUG ( 936):
I/DEBUG ( 936): backtrace:
I/DEBUG ( 936): #00 pc 0002a9d0 /system/lib/libMali.so (_mali_osu_abort+8)
I/DEBUG ( 936): #01 pc 000163f4 /system/lib/egl/libEGL_mali.so (_egl_create_sync_KHR+740)
I/DEBUG ( 936): #02 pc 0000de9c /system/lib/egl/libEGL_mali.so (eglCreateSyncKHR+60)
I/DEBUG ( 936): #03 pc 0000e2c1 /system/lib/libEGL.so (eglCreateSyncKHR+52)
I/DEBUG ( 936): #04 pc 00019135 /system/lib/libsurfaceflinger.so
I/DEBUG ( 936): #05 pc 0001debb /system/lib/libsurfaceflinger.so
I/DEBUG ( 936): #06 pc 00017009 /system/lib/libsurfaceflinger.so
I/DEBUG ( 936): #07 pc 00010b35 /system/lib/libutils.so (android::Looper::pollInner(int)+412)
I/DEBUG ( 936): #08 pc 00010c29 /system/lib/libutils.so (android::Looper::pollOnce(int, int*, int*, void**)+92)
I/DEBUG ( 936): #09 pc 000171e5 /system/lib/libsurfaceflinger.so
I/DEBUG ( 936): #10 pc 00018241 /system/lib/libsurfaceflinger.so (android::SurfaceFlinger::run()+8)
I/DEBUG ( 936): #11 pc 0000096b /system/bin/surfaceflinger
I/DEBUG ( 936): #12 pc 0000e647 /system/lib/libc.so (__libc_init+50)
I/DEBUG ( 936): #13 pc 00000a20 /system/bin/surfaceflinger
I/DEBUG ( 936): stack:
I/DEBUG ( 936): be864770 41306090 /system/lib/libMali.so
I/DEBUG ( 936): be864774 43103250
I/DEBUG ( 936): be864778 40005df8
I/DEBUG ( 936): be86477c 00000001
I/DEBUG ( 936): be864780 400e7690
I/DEBUG ( 936): be864784 00000000
I/DEBUG ( 936): be864788 10000001
I/DEBUG ( 936): be86478c be86487c [stack]
I/DEBUG ( 936): be864790 be864830 [stack]
I/DEBUG ( 936): be864794 4122d3d0 /system/lib/libMali.so (_mali_sys_printf+28)
I/DEBUG ( 936): be864798 41739980
I/DEBUG ( 936): be86479c be8647ac [stack]
I/DEBUG ( 936): be8647a0 43103250
I/DEBUG ( 936): be8647a4 404773f4 /system/lib/egl/libEGL_mali.so (_egl_create_sync_KHR+740)
I/DEBUG ( 936): be8647a8 4047b7e8 /system/lib/egl/libEGL_mali.so
I/DEBUG ( 936): be8647ac 00000000
I/DEBUG ( 936): #00 be8647b0 41306090 /system/lib/libMali.so
I/DEBUG ( 936): be8647b4 404773f8 /system/lib/egl/libEGL_mali.so (_egl_create_sync_KHR+744)
I/DEBUG ( 936): #01 be8647b8 40005df8
I/DEBUG ( 936): be8647bc 40005df8
I/DEBUG ( 936): be8647c0 00000000
I/DEBUG ( 936): be8647c4 000030f9
I/DEBUG ( 936): be8647c8 00000001
I/DEBUG ( 936): be8647cc 4046eea0 /system/lib/egl/libEGL_mali.so (eglCreateSyncKHR+64)
I/DEBUG ( 936): #02 be8647d0 ffffffbc
I/DEBUG ( 936): be8647d4 4026ee0c /system/lib/libEGL.so
I/DEBUG ( 936): be8647d8 be8647ec [stack]
I/DEBUG ( 936): be8647dc 4046ee60 /system/lib/egl/libEGL_mali.so (eglCreateSyncKHR)
I/DEBUG ( 936): be8647e0 000030f9
I/DEBUG ( 936): be8647e4 4022c2c3 /system/lib/libEGL.so (eglCreateSyncKHR+54)
Hi guanhb,
May I ask which hardware platform you are using?
AFAIK, r3p2 does not officially support KK. There may be some potential issues when applying r3p2 to KK.
Is it possible to update the DDK to r4p0 and have a test again?
Please let me know the result when it is available.
Thanks,
Frank
