Mali texture compression: exr_to_tga command
Hi guys,
First question here in the forum - sorry, couldn't find any answer after a bit of Googling. I was trying to play around with your texture compression tool by converting some HDRs (in EXR format) I have around. However, I get the following error:
exr_to_htga: not found
I can't seem to find any mention to an HTGA file format anywhere. Would you mind telling me where can I get that from?
Cheers.
