Hello, I`have arm board on rk3288 with mali t760. If I install an operating system based on Linux kernel (Ubuntu for example), will I be able to use OpenCL ? Is there open access driver for OpenCL or i can use driver from Mali T6xx (this) ?
Hi Avagetto,
To the best of my knowledge, we do not currently provide drivers for the rk3288 on malideveloper.arm.com. It is worth approaching the silicon vendor to inquire about their roadmap for releasing the necessary drivers. The drivers available at malideveloper.arm.com should fail to work on anything other than the GPU model and core revision they were built to target.
Hth,
Chris
Hi avagetto,
More information relating to your question is available in the thread of someone else who asked for the same thing at http://community.arm.com/thread/6580.
As Guillaume says, the release of Mali T7XX user space binaries to complement the kernel driver are in our release roadmap but not for the immediate future. As Chris said, your best bet may be contacting the silicon vendor to see if they can provide you the drivers you need.
Hope this helps,
Rich
Unfortunately, the probability that rockchip will provide the driver tends to zero.
