Looking at this post
Graphics and Compute Development on Samsung Chromebook « Mali Developer Center Mali Developer Center
I have see that is possible to have Mali GPU hardware acceleration on Samsung ARM Chromebook with Ubuntu.
On the post you guide all the process to prepare an sd card to install ubuntu with mail support on chromebook, could you provide even the imagefile of the generated sd card?
Hi yebyen,
Thanks for the feedback, glad it's all working now. Enough people have tripped over the mesa thing that we should address it in the guide, and I agree we could do more in the guide to confirm a working setup. I'll pass this on to the relevant people.
nobody else can provide the drivers and even regular users need drivers sometimes
Strictly speaking there are people downstream of us that could do this (Samsung/Google in this case) but supporting Linux environments tends to be quite far down the priority list. We do this in an effort to provide an easily accessible, relatively cheap development platform to those wishing to develop GLES applications on Mali hardware, but we're by no means the gatekeepers to providing such support!
bonus points to the thread you linked because you all mentioned "feh"
Are you a dev?
Cheers,
Chris
... nobody else can provide the drivers and even regular users need drivers sometimes Strictly speaking there are people downstream of us that could do this (Samsung/Google in this case) but supporting Linux environments tends to be quite far down the priority list. We do this in an effort to provide an easily accessible, relatively cheap development platform to those wishing to develop GLES applications on Mali hardware, but we're by no means the gatekeepers to providing such support! bonus points to the thread you linked because you all mentioned "feh" Are you a dev? Cheers, Chris
I am very computer sometimes, others not so much. It's true that there is not much help from Samsung or Google on this front! I was very glad to find the drivers here, even more now that I start to see how they are put together.
So far EFL compiled from git, the biggest hurdle is that -lGLESv2 and -lEGL are both stubs, missing everything you would normally expect to find in them with the actual functionality implemented in libmali.so, so everything that links either of those needs to -lmali as well or undefined symbol glTexImage2D, etc. Caught at configure time building EFL. That is why chromium from ubuntu doesn't access the acceleration features too, I'd assume, because it doesn't link in libmali.so.
I think it will work now, but there's an hour of compiling left maybe or more before I see, and it's time for bed now!
Kingdon
Well, performance is very good, in spite of something apparently not being configured correctly so it seems to have fallen back to software, now it's clearly not near as snappy as ChromeOS.
./configure --prefix=/usr/local --enable-harfbuzz --enable-image-loader-webp --enable-multisense --enable-xine --enable-xinput22 --with-opengl=es --enable-egl
is what I asked for to configure efl, mostly the same options as the options ubuntuhandbook/nineteen.sh would have passed, except for the last two
http://paste.ubuntu.com/9114197/
My extremely naive patch which got me past configure, I think what might be missing now is that the evas engine for egl is actually wayland only, and that is why I am where I am now. Nothing in this case seems to have actually been linked against EGL or GLESv2. Funny, configure would not let me proceed without proving I could link to them and that they had the right stuff (libmali.so). I guess that's because I asked it to...
Please note that the Linux on Chromebook with ARM® Mali™ GPU has moved to the community website and it has also be updated to use the latest r5p0 drivers. Now you don't need to link directly against libmali.so as the driver archives come with symlinks for the standard graphics and compute libraries. We haven't fixed the lack of hardware-accelerated windowing system using OpenGL ES yet but it's clearly something we would like to have.
Hello Guillaume,
I just found this guide recently and have been trying to get it to work. Unfortunately, some of the links in the config script are broken. Specifically, it works until downloading the Mali drivers. Would it be possible to get updated links that I could put in the script?
Also, I wanted to try it using the manual process but I don't believe I have the syntax correct. When I run a command nothing happens. Any help would be greatly appreciated.
Thanks for your help. It's all working now.
