I am working on GLES program using ARM GLES3.0 Emulator ver 1.4.
It gives shader compilation error ““Unexpected # directive '#include consts_value “” if shader has the following directive #include
#ifdef MACRO_1 #include consts_value; #else uniform mat4 mvp; #endif
I don’t face this issue with ARM GLES3.0 Emulator ver 1.3.
The MACRO _1 is never defined. So the program should use the #else. But why is there syntax error with “#include”?
Hi Sunil,
According to the spec (http://www.khronos.org/registry/gles/specs/3.1/GLSL_ES_Specification_3.10.pdf) section 3.4 #include is not one of the supported preprocessor directives, so that's why that line is producing an error. The spec states "Any directive not listed above will cause a diagnostic message and make the implementation treat the shader as ill-formed", it doesn't mention whether the directive is inside a conditional block or not, so the current version looks to check the shader is well formed before evaluating anything. Not doing this in previous versions was actually a source of bugs which is why it's tightened up.
Hth,
Chris
