I'm sure this is a very easy question for most of you to asnwer. I sadly seem to be having quite a bt of difficulties to get the driver to compile.
I have compiled the ump.ko kernel module. For that to work i had to uncomment these lines:
ifeq ($(ARCH), arm) # when compiling for ARM we're cross compiling export CROSS_COMPILE ?= $(call check_cc2, arm-linux-gnueabi-gcc, arm-linux-gnueabi-, arm-none-linux-gnueabi-) endif
ifeq ($(ARCH), arm)
endif
The compile command i used:
KDIR=/usr/lib/modules/3.8.13.23-3-ARCH/build BUILD=release make
Which did it for the ump module.
However, the mali module isn't that easily persuaded to compile.
I'm compiling that module with this line:
KDIR=/usr/lib/modules/3.8.13.23-3-ARCH/build USING_UMP=1 BUILD=release make
and that gives me this compile output:
Makefile:76: /root/mali/DX910-SW-99002-r4p0-00rel1/driver/src/devicedrv/ump/Module.symvers Makefile:110: CONFIG_TRACEPOINTS required for profiling make ARCH=arm -C /usr/lib/modules/3.8.13.23-3-ARCH/build M=/root/mali/DX910-SW-99002-r4p0-00rel1/driver/src/devicedrv/mali modules make[1]: Entering directory '/usr/src/linux-3.8.13.23-3-ARCH' make[1]: arm-none-linux-gnueabi-gcc: Command not found Building modules, stage 2. MODPOST 0 modules make[1]: Leaving directory '/usr/src/linux-3.8.13.23-3-ARCH' rm: cannot remove ‘__malidrv_build_info.c’: No such file or directory rm: cannot remove ‘__malidrv_build_info.o’: No such file or directory Makefile:161: recipe for target 'all' failed make: *** [all] Error 1
MODPOST 0 modules
Disabling those lines like i did for the ump module only causes the line: "make[1]: arm-none-linux-gnueabi-gcc: Command not found" to not be in the output. The rest is the same.
It smells like i'm missing a step somewhere. But i'm merely following the documentation.
Some guidance in commands to use would be greatly appreciated.
** in case you wonder, yes i run this as root. I know it's bad practice but if i can't get my gpu to work then i certainly won't bother setting up a user environment **
Best regards,
Mark
Small update.
When i execute:
make -C /lib/modules/`uname -r`/build M=`pwd`
I do get a "mali.o" but not the final stel in actually creating the kernel module (.ko)...
Hi markg85.
A few questions:
Also it's worth mentioning that the sources we release on the site are taken straight from the source that we release to partners, but it is intended to be ported/integrated for a specific SoC as part of its bringup. I wouldn't expect it to build and work perfectly as-is for any given platform/kernel.
Thanks,
Chris
Hi Chris,
I'm working on the Odroid-X board. But the other odroid versions (X2, U2/3 ..) all seem to have the same mali 400 gpu so i don't expect that to be an issue.
As for the userspace binary. This site (arm.com) provides the sources to build the binary userspace driver: Open Source Mali GPUs Linux EXA/DRI2 and X11 Display Drivers « Mali Developer Center so i guess i have that
One thing i wasn't counting on is the lack of gles binary blobs. But that also shouldn't be much of an issue to compile this driver. It just means that i have to wait a while till hardkernel releases the binary gles blobs for r4p0. I think they might have even done so already for the Odroid-U3.
Regards,
Hi Mark,
The GLES blobs is what I meant, but if they've released it then that's not a problem. Commits · hardkernel/linux · GitHub seems to have r4p0 support merged in last Tuesday, so assuming that kernel works for Odroid-X (I believe it should) then is there any reason you're not starting from there? If so you could probably use it as a reference. Also from the commit log it looks like they're using DRM not UMP, for what it's worth.
Hth,
Heh
I wasn't aware of that.
I also spoke with one of the odroid folks who also happens to know a lot about archlinuxarm. Turns out that there are packages (under names i wasn't expecting) to get everything working just fine.
I was not aware of that could you let us know the packages as this will help people googling for this later
I actually wanted to do that in my last reply, but the arm board was kinda busy compiling. Which i didn't want to interrupt.
So here we go. If you run archlinuxarm on the odroid-x with the kernel: 3.8.13.23-3-ARCH then you can follow these instructions to get hardware accelerated opengl es.
Install the packages:
- xf86-video-armsoc-odroid
- xf86-video-modesetting
- odroid-libgl
That "should" be all you need.
In my case i had the issue that starting X still didn't work because it couldn't find screens.. So i asked how to get around that issue and was given this conf file for xorg (you should save it as "/etc/X11/xorg.conf.d/50-armsoc.conf"):
Section "Device" Identifier "Mali-Fbdev" Driver "armsoc" Option "fbdev" "/dev/fb0" Option "Debug" "false" Option "DPMS" "false" EndSection Section "Screen" Identifier "Default Screen" Device "Mali-Fbdev" DefaultDepth 24 EndSection Section "DRI" Mode 0666 EndSection
Section "Device"
Driver "armsoc"
EndSection
Section "Screen"
Device "Mali-Fbdev"
DefaultDepth 24
Section "DRI"
Mode 0666
That should help some people googling for this issue
There is one issue i didn't find a suitable workaround for. Much applications want "libGL.so.1" to even open. They simply crash if you don't have this file (which you don't have if you follow the above).
So starting KDE: crash
Starting some login managers: crash
What is working is startx with twm (very ugly window manager). Starting KDM (KDE's login manager) and starting openbox from KDM all seem to work just fine.
Perhaps someone here can give me some hint on how to work around that issue? I know that the mali 400 doesn't have opengl support (only opengles) but there must be some trick to let the apps "think" that there is opengl just so they don't crash.
That has to be the easiest X config I've ever seen.
As for GL, if you did symlink libGL.so.1 to GLES, then you might be lucky, but I think more often than not it would barf. Generally the apps need to be GLES versions, for example XBMC has an option to build for GLES. Not sure how variables such as that would work with package managers, would you have xbmc and xbmc-gles?
Another issue is that even when apps use GLES, they tend to depend on the mesa GLES software implementation specifically, which is one of our most common pitfalls on the Chromebook as the mesa libs will completely override any other implementation on the board, removing the hardware acceleration. This doesn't seem to be the case for GL where the OS regards GL as an interface, which many different packages (e.g. MESA, nVidia, AMD, blah) can satisfy, but GLES doesn't seem to be treated the same way. EDIT: Apparently this is only on Ubuntu, Arch treats it as an interface.
I've had a look at these packages and it appears that you've got everything you need to get Mali working in X11. Mali-400 driver doesn't support OpenGL API so if you want to run applications that depend on OpenGL, you will need to fall back to Mesa libraries. Please note that you will be limited to software rendering instead.
To get a fully functional 3D desktop, I'd recommend using a compositing/window manager that supports GLES such as certain branches of compiz, enlightenment, kwin or gnome-shell. For example: you can install package "kdebase-workspace" which contains kwin_gles that you can use instead of the default kwin WM. Alternatively you can use xfwm4, openbox for a functional 2D desktop.
I hope this helps.
Tu
