How to run offline shader compiler?
I tried running the off line shader compiler on ubuntu64, for Mali-400 target.
This fails, see below.
How can I get it to run? The malisc in top level dir does seem to work, but does not support Mali-400.
bram@Ubuntu64:~/Mali_Offline_Compiler_v4.1.0$ export MALICM_LOCATION=`pwd`
bram@Ubuntu64:~/Mali_Offline_Compiler_v4.1.0$ echo $MALICM_LOCATION
/home/bram/Mali_Offline_Compiler_v4.1.0
bram@Ubuntu64:~/Mali_Offline_Compiler_v4.1.0$ cd Mali-400/
bram@Ubuntu64:~/Mali_Offline_Compiler_v4.1.0/Mali-400$ ls -al
total 476
drwxr-xr-x 2 bram bram   4096 Feb 25 15:31 .
drwxr-xr-x 4 bram bram   4096 Feb 25 15:27 ..
-rwxr-xr-x 1 bram bram 457024 Aug 19  2013 libMali400SC.so
-rwxr-xr-x 1 bram bram  10472 Aug 19  2013 malisc
-rw-r--r-- 1 bram bram    125 Feb 25 15:31 shadow.fp
-rw-r--r-- 1 bram bram    145 Feb 25 15:31 shadow.vp
bram@Ubuntu64:~/Mali_Offline_Compiler_v4.1.0/Mali-400$ ./malisc --core=Mali-400 --vert shadow.vp
Failed to open libMali400SC.so
bram@Ubuntu64:~/Mali_Offline_Compiler_v4.1.0/Mali-400$ echo $MALICM_LOCATION
bram@Ubuntu64:~/Mali_Offline_Compiler_v4.1.0/Mali-400$ ldd ./libMali400SC.so
  linux-vdso.so.1 =>  (0x00007fff897d2000)
  libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f0b8ccad000)
  /lib64/ld-linux-x86-64.so.2 (0x00007f0b8d302000)
  • Hi bram,
    Thanks for the report.
    The reason Offline Shader Compiler for ARM Mali-400 doesn't work is that it fails to load libMali400SC.so.
    Please try following commands:
    cd Mali-400/
    export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:`pwd`
    That should solve your problem.
    I will raise this issue internally to make sure it is documented in the User Guide for the next release.
    Thanks,
    Jacek
