Nexus 10 - render to external rendertarget works only in landscape
Note: This was originally posted on 8th July 2013 at http://forums.arm.com
We're developing live wallpaper with OpenGL ES 2.0 on Nexus 10.
Live wallpaper uses 2 small (128x128) external framebuffers to make ping-pong rendering between them to blur image.
While this works perfectly fine on any device (even on aged Motorola Milestone) there is a strange issue with Nexus 10. This works only if device is in landscape orientation. If device is rotated in any other position (90, 180 or 270 degrees) framebuffers has only clear color. I've set `glClearColor` to red so it is clearly visible that these framebuffers are cleared but nothing is rendered into them.
I've tested it on Tegra 2, Tegra 3, Adreno 200, Adreno 320, 2 PowerVR GPUs and it works just fine.
This looks like some weird driver bug, but might also be some specifics of Mali driver. Please advice.
Code excerpts.
Init framebuffers:
private void initBloomStuff() {
  mBloomTextureID = loadTexture("textures/empty128.png");
  mBloomVertTextureID = loadTexture("textures/empty128.png");
  mBloomFBHeight = 128;
  mBloomFBWidth = 128;
  float blurSize = 1.0f;
  // Texel offset for blur filter kernel
  m_fTexelOffset = 1.0f / mBloomFBWidth / blurSize;
  ByteBuffer tmpFB, tmpRB;
  IntBuffer handle, renderbuffers;
  int result;
  tmpFB = ByteBuffer.allocateDirect(4);
  tmpFB.order(ByteOrder.nativeOrder());
  handle = tmpFB.asIntBuffer();
  GLES20.glGenFramebuffers(1, handle);
  framebufferHandle = handle.get(0);
  GLES20.glBindTexture(GLES20.GL_TEXTURE_2D, mBloomTextureID);
  GLES20.glBindFramebuffer(GLES20.GL_FRAMEBUFFER, framebufferHandle);
  GLES20.glFramebufferTexture2D(GLES20.GL_FRAMEBUFFER, GLES20.GL_COLOR_ATTACHMENT0, GLES20.GL_TEXTURE_2D, mBloomTextureID, 0);
  checkGlError("FB 1");
  tmpRB = ByteBuffer.allocateDirect(4);
  renderbuffers = tmpRB.asIntBuffer();
  GLES20.glGenRenderbuffers(1, renderbuffers);
  checkGlError("FB 1 - glGenRenderbuffers");
  depthbufferHandle = renderbuffers.get(0);
  GLES20.glBindRenderbuffer(GLES20.GL_RENDERBUFFER, depthbufferHandle);
  checkGlError("FB 1 - glBindRenderbuffer");
  GLES20.glRenderbufferStorage(GLES20.GL_RENDERBUFFER, GLES20.GL_DEPTH_COMPONENT16, mBloomFBWidth, mBloomFBHeight);
  checkGlError("FB 1 - glRenderbufferStorage");
  GLES20.glFramebufferRenderbuffer(GLES20.GL_FRAMEBUFFER, GLES20.GL_DEPTH_ATTACHMENT, GLES20.GL_RENDERBUFFER, depthbufferHandle);
  checkGlError("FB 1 - glFramebufferRenderbuffer");
  result = GLES20.glCheckFramebufferStatus(GLES20.GL_FRAMEBUFFER);
  if (result != GLES20.GL_FRAMEBUFFER_COMPLETE) {
   Log.d(TAG, "Error creating framebufer 1: " + result);
  } else {
   Log.d(TAG, "Created framebufer 1: " + result);
  GLES20.glBindRenderbuffer(GLES20.GL_RENDERBUFFER, 0);
  GLES20.glBindTexture(GLES20.GL_TEXTURE_2D, 0);
  GLES20.glBindFramebuffer(GLES20.GL_FRAMEBUFFER, 0);
  framebufferVertHandle = handle.get(0);
  GLES20.glBindTexture(GLES20.GL_TEXTURE_2D, mBloomVertTextureID);
  GLES20.glBindFramebuffer(GLES20.GL_FRAMEBUFFER, framebufferVertHandle);
  GLES20.glFramebufferTexture2D(GLES20.GL_FRAMEBUFFER, GLES20.GL_COLOR_ATTACHMENT0, GLES20.GL_TEXTURE_2D, mBloomVertTextureID, 0);
  checkGlError("FB 2");
  checkGlError("FB 2 - glGenRenderbuffers");
  depthbufferVertHandle = renderbuffers.get(0);
  GLES20.glBindRenderbuffer(GLES20.GL_RENDERBUFFER, depthbufferVertHandle);
  checkGlError("FB 2 - glBindRenderbuffer");
  checkGlError("FB 2 - glRenderbufferStorage");
  GLES20.glFramebufferRenderbuffer(GLES20.GL_FRAMEBUFFER, GLES20.GL_DEPTH_ATTACHMENT, GLES20.GL_RENDERBUFFER, depthbufferVertHandle);
  checkGlError("FB 2 - glFramebufferRenderbuffer");
   Log.d(TAG, "Error creating framebufer 2: " + result);
  } else {
   Log.d(TAG, "Created framebufer 2: " + result);
  mTriangleVerticesVignette = ByteBuffer.allocateDirect(mQuadTriangles.length * FLOAT_SIZE_BYTES).order(ByteOrder.nativeOrder()).asFloatBuffer();
  mTriangleVerticesVignette.put(mQuadTriangles).position(0);
Render to FB:
  GLES20.glUseProgram(mProgram);
  GLES20.glBindTexture(GLES20.GL_TEXTURE_2D, mStemTextureID);
  drawBird();
  GLES20.glBindTexture(GLES20.GL_TEXTURE_2D, mSphereTextureID);
  drawSphere();
  GLES20.glViewport(0, 0, mBloomFBWidth, mBloomFBHeight);
  // GLES20.glBindRenderbuffer(GLES20.GL_FRAMEBUFFER, depthbufferHandle);
  GLES20.glClearColor(1.0f, 0.5f, 0.5f, 1.0f);
  GLES20.glClear(GLES20.GL_COLOR_BUFFER_BIT | GLES20.GL_DEPTH_BUFFER_BIT);
  drawBird();
  drawSphere();
  GLES20.glViewport(0, 0, screenWidth, screenHeight);
  // GLES20.glBindRenderbuffer(GLES20.GL_FRAMEBUFFER, 0);
Ping-pong rendering between 2 FBs to blur image:
  GLES20.glUseProgram(mBloomProgram);
  GLES20.glUniform1i(mBloom_sTexture, 0);
  GLES20.glUniform1f(mBloom_bloomFactor, 0.8f);
  GLES20.glActiveTexture(GL10.GL_TEXTURE0);
  GLES20.glUniform1f(mBloom_TexelOffsetX, m_fTexelOffset);
  GLES20.glUniform1f(mBloom_TexelOffsetY, 0.0f);
  drawBloom();
  GLES20.glUniform1f(mBloom_TexelOffsetX, 0.0f);
  GLES20.glUniform1f(mBloom_TexelOffsetY, m_fTexelOffset);
  drawBloom();
  GLES20.glUniform1f(mBloom_TexelOffsetX, m_fTexelOffset / 2);
  GLES20.glUniform1f(mBloom_TexelOffsetY, m_fTexelOffset / 2);
  drawBloom();
You can download test APK here: https://dl.dropboxus...perAnimTest.apk
It is a live wallpaper app, install it and select 'Test' live wallpaper (has an icon with rose).
As you can see, default landscape orientation you will see some 'bloom' effect around bird which is implemented by ping-pong rendering between 2 framebuffers. In any other device orientation it doesn't work and fills FB with clear color (red).
I've also posted this question on stackoverflow: http://stackoverflow...ly-in-landscape and filed a bug on Google Code: http://code.google.com/p/android/issues/detail?id=57391
  • Note: This was originally posted on 9th July 2013 at http://forums.arm.com
    Thanks for reporting - I will raise with the driver support team.
    Regards,
    Iso
  • Note: This was originally posted on 10th July 2013 at http://forums.arm.com
    Regards,
    Iso
    Thank you for paying attention to this issue. Will be great to see it fixed in next firmware update for Nexus10.
  • Note: This was originally posted on 12th July 2013 at http://forums.arm.com
    We have identified the issue and will have a fix in our next driver release; how soon this gets picked up by device manufacturers downstream is somewhat out of our control unfortunately.
    We have a workaround  from the application side for existing devices, which is to call glViewport after glBindFramebuffer.
    Hope that helps and thanks again for reporting.
    Iso
  • Note: This was originally posted on 13th July 2013 at http://forums.arm.com
    Iso
    Thank you for such quick turnaround on this. Your workaround to call glViewport after glBindFramebuffer really helped us.
    I understand that getting a driver fix into final device is a long way. I will post a link to this into Google issue tracked - hopefully this will force them to communicate with ARM faster and they will release a firmware update as soon as you update driver.
    Once again, thank you very much.
    Best regards,
       Alex
