OES_EGL_image_external Render Texture without glTexture2D
Note: This was originally posted on 30th May 2013 at http://forums.arm.com
Is there any possibility to use OES_EGL_image_external with Mali 400 on Linux.
I know this feature is used in Android ICS. But I can't find any example, reference code or  document of that.
Thanks & Regards
Piyush Verma
  • Note: This was originally posted on 31st May 2013 at http://forums.arm.com
    Hi Piyush,
    Thanks for the question, yes this extension is available for Linux as well as Android. The mechanism of getting data into an EGLImage will differ on Linux, but on the GLES side it's exactly the same for sampling etc. I'm afraid I don't think we currently have any sample code for this, but the extension documentation should be all you need:
    http://www.khronos.org/registry/gles/extensions/OES/OES_EGL_image_external.txt
    Hope this helps,
    Chris
  • Note: This was originally posted on 1st June 2013 at http://forums.arm.com
    Hi Piyush,
    http://www.khronos.o...ge_external.txt
    Hope this helps,
    Chris
    Hi Chris,
    That's really gr8 new that it support external texture.
    There is still some open question like what image format it support....
    We are going to try it. thanks you very much for this gr8 news.
    Thanks & Regards
    Piyush Verma
