Hi derekcentrico,The kernel space modules (.ko's) only work in conjunction with userspace libraries (.so's) such as libGLESv2.so and libEGL.so, which expose the GLES and EGL APIs respectively. Do your applications use these libraries, and if so are they present on the target device? If your target device is a commercial one such as a phone or tablet then they will ship with these drivers present in the filesystem, but if you are working on a development board or a custom build of Android then this may not be the case. Can I ask what device you are having trouble with?Thanks,Chris
#0 0 android0 1 mali
insmod /system/lib/modules/ump.koinsmod /system/lib/modules/mali.ko
