Mali user-space drivers
Note: This was originally posted on 27th December 2011 at http://forums.arm.com
From what I understand, each ARM licensee provides their own Linux user-space Mali drivers. I assume the sentence "To build a functional OpenGL ES or OpenVG driver you need access to the  full source code of the Mali DDK, which is provided under the standard  ARM commercial licence [sic] to all Mali GPU customers." from pages like Mali Drivers refers to these user-space drivers.
I haven't been able to find any open-source userspace drivers for Mali. Does the ARM commercial license prohibit releasing them?
I'm interested in using ARM-based boards for development; most of the ones I'm interested in have Mali graphics. But I am not planning on running Linux or Android. As a start, I would like to get a hardware-accelerated video driver for OpenBSD.
I assume most of the Mali user-space code from the different vendors is generic based on what is provided by ARM. Is there a way to release this code? If not, what does it take to get the source code under the ARM commercial license so I can do a clean-room reverse engineered version?
Thank you,
Vladimir Sedach
  • Note: This was originally posted on 28th December 2011 at http://forums.arm.com
    Yes, I'm also very interested in having acceleration working on non linux platforms. Is there any way to get hands on gpu register documentation or just have a look on code? Or is there are any precompiled libraries for *BSD oses?
  • Note: This was originally posted on 24th January 2012 at http://forums.arm.com
    Luc Verhaegen.
